STOP due to Software limit switch +A3
  • lekanoje
  • May 14, 2025 at 2:57 PM
  • lekanoje
    22
    I just encountered a STOP due to software limit switch + A3 on program Line 45 for a LIN move for a pick and place program. Any suggestions and inputs will be appreciated.
    Thank you
    GetAttachmentThumbnail?id=AAMkADc2NTRmNzU4LTgxZDMtNDc2My1iMjlmLTA5NTRmM2U2YmJkNgBGAAAAAABCHYYyedh7SJLOXc3bqctnBwCO3AUbH1UJR4gzudNi34O9AAAAAAEMAACgdkM%2FWjZWQpiVfnuDTxkxAABvQ4LcAAABEgAQAC%2B5u0%2BkmBJNpEq6G8raGG8%3D&thumbnailType=2&token=eyJhbGciOiJSUzI1NiIsInR5cCI6IkpXVCIsImtpZCI6IkJEaGJuMWMzdU9JcGhGcEFqMStvS0pwYXQ4TT0iLCJ4NXQiOiJCRGhibjFjM3VPSXBoRnBBajErb0tKcGF0OE09Iiwibm9uY2UiOiI0X3l1Ukp3d1FfNjVZSDk1ZWZKZVFRVkNqUXBQVDI1MkpxcV9WeWhGaFlmaGdkMHlSVXpqaVZIX29PTFROSEdwUmdsRV9KRTBKSmY5eEpFWjZrZUo3S2VJYklmWmZiMDlOTTczYVliQTl4b0FMQXY0VEZZOWl1LTZudXdVWTdWVFc5MGg0eUgzRDJDOE12SzRXWUEzUUJXSVpsZWpzb0JfUnRzWldRSTcxWlEiLCJpc3Nsb2MiOiJTSjBQUjA3TUI5MTI0Iiwic3JzbiI6NjM4ODI2OTk3NzU5MzA1ODgxfQ.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.qH5r8mw0mOfDFYdTr6ic9ZdUTDqJ6GZA-goiyqFkb4UVo9j1iY7fOUVDH3KbHSeFDD4jUOCtpK24FZFnnO6vyqGa4yN3HeeHY_DnFOG2eGgmDltbCmVa2ndXfBYfuXo4r-FsAq8qnMh_4rBdB2VInICMqdyMomhtvriVekR-qTC0JI1JeAz7J1e3CHkZ_CVP0CoQm4pjJKYqAY7OWI5gwT_FZqWMgoDL__78rcabLSAAxOq8YSnBTms22bXuovs82tNZTemYTpSfmVz36-5RAbpxvgm8IOmt-mCfBFECBMzp0tzcLe4a8hU6rywo44yzRfXfWiCH1EQYjshWrDOghQ&X-OWA-CANARY=X-OWA-CANARY_cookie_is_null_or_empty&owa=outlook.office.com&scriptVer=20250502003.07&clientId=8CA17D82564B40B9A4802AABD52FFC75&animation=true&persistenceId=3ab8c8c1-627e-47b6-babb-80ef7d89e5f6
    Images
      • 180.17 kB
      • 900 × 1,200
      • 8
  • panic mode
    1,280
    13,086
    • May 14, 2025 at 3:24 PM
    that means robot cannot move more than requested. you need to modify your program so that all points are within work envelope of the robot. if needed, you may have to offset the piece you are working on, or consider using additional axis such as positioner or linear rail.
  • lekanoje
    22
    • May 14, 2025 at 4:45 PM
    Hi panic mode,
    The axis in question is + A3 software limit switch. I used RoboDK simulation to generate the program using python script. The simulation runs well. Just wondering if there is a clear step in getting this resolved. I am just a new learner.
  • Fubini
    278
    1,889
    • May 14, 2025 at 5:54 PM
    Read about status and turn in KUKA manuals for your robot and software version. For your initial turn of A3 the shortest path to the final axis values leads through a software limit switch. Either add a ptp in front of the lin to change A3 turn or shift base so the robot can reach target position without limit switch violations. If stuff works inside simulation but not on robot usually is caused by simulation not being a digital twin of the real robot. So check simulation setup for tools, bases, .... compared to real robot.
  • lekanoje
    22
    • May 16, 2025 at 10:36 PM
    Hi Fubini,
    Thank you. I have resolved the problem. I toggle the - A3 axis and saved the position and it works
Similar Threads
  • Unreachability check
    • Mohamad Sayegh
    • February 1, 2022 at 11:49 AM
    • KUKA Robot Forum
  • SkyeFire
