Hello guys,
i have a trouble related Siemens S7-1200 PLC and KUKA KRC2 controller communcaiton via Profibus.
Everything seem okey, but not exist I/O transfer from plc to robot and inverse.
I will share pictures from Tia Portal and Kuka flexpendant screen. Could you please help to me if you have available information related root couse of my problem?
First of all i want to list the Kuka controller side configuration views below.
https://ibb.co/LXspk3ns -> isosys.ini and pfbms.ini files in the destination C:/KRC/ROBOTER/INIT
https://ibb.co/VczRBxsb ->isosys.ini Driver section
https://ibb.co/R4cpF010 ->isosys.ini Mapping
https://ibb.co/23yDyF4C ->a view from pfbms.ini
https://ibb.co/Fk1QT6h9 ->pfbms.ini Master settings
https://ibb.co/ccFczs23 ->pfbms.ini Master settings
As second one, Tiaportal settings are below.
https://ibb.co/wZ9tnxn9 ->Siemens PLC Profibus Module and its Adress
https://ibb.co/PZyVwGqg -> Robot's adress in the TiaPortal
https://ibb.co/Q7HwrdBr ->Devices and Newtorks
I can share more detail if it's necessary. Thanks for in advance.
