KUKA Agilus KR10 R1100 HM-SC
  • aes
  • May 8, 2025 at 9:54 PM
  • aes
    • New
    I have an agilus robot, the A4 servo brake failed. When replacing this motor, the oil in this axis drained out. does anyone on here know what spec of oil should go in this joint? Looking through the manuals, its not a serviced item so it is not specified.
    panic mode
    1,262
    13,026
    • May 9, 2025 at 2:12 PM
    • New
    agilus robots do not use oil. they use grease which is good for lifetime of the robot.
  • aes
    • May 11, 2025 at 10:02 PM
    • New
    Thanks for the reply. Interesting, about 50mL of oil came out of the joint, while replacing the motor, the oil must have separated from the grease
