Error at input 2 & input 3: KUKA KR C4 Compact
  • bruun0902
  • May 8, 2025 at 11:28 AM
  • bruun0902
    I am working on a KUKA KR C4 Compact controller. I will try to describe the issue:
    When I start up the KUKA (in T1 mode), I get no error messages. Everything looks fine and i can move the robot.
    However, when I press my Reset button to activate the contactor relay, I get the following errors:
    • Safe device CIB SR Safety Module (SION-SIB-SR): Error at input 2 - originator: KS
    • Safe device CIB SR Safety Module (SION-SIB-SR): Error at input 3 - originator: KS
    • Safety Stop - originator KS
    I understand that input 2 is "operator safety" (door switches), and input 3 is "acknowledge operator safety" (reset button).
    These are connected to the X11 interface on pins 3-4 and 12-13 for the contactor relay associated with the door switches, and on X11 pins 5-6 and 14-15. These connections have been thoroughly checked and tested, but I cannot clear the error messages once they appear.
    I am using a SICK UE410-MU4T5 safety relay.
    attached is the wireing and fail message:
    Images
      • 38.6 kB
      • 1,672 × 614
      • 11
      • 147.86 kB
      • 900 × 1,200
      • 7
  • bruun0902
    • May 8, 2025 at 2:18 PM
    The reset-button is connected directly to terminals that are directly connected to the X11 - maybe the fail is here? Connected through a manual button?
  • SkyeFire
    1,060
    9,456
    • May 8, 2025 at 4:36 PM
    Quote from bruun0902
    Which terminals?
  • bruun0902
    • May 9, 2025 at 9:34 AM
    Quote from SkyeFire
    Which terminals?
    reset-button contacts directy transfered to terminals - they are then wired to the X11 pins. Should they go through a contactrelay?
  • bruun0902
    • May 9, 2025 at 9:58 AM
    If i SC the fence-gate i get no errors on that input. So fail at contact? Fence goes to Sick safety relays I3&i4. from I3&I4 to Q3&Q4. Q3&Q4 to K3 &K4 A1(24V). The X11 pins then on the NO-gates of the contact.
Similar Threads
  • KUKA INT to REAL
    • Evstahi
    • May 21, 2020 at 9:59 AM
    • KUKA Robot Forum
  • VisionTech Calibration Grids
    • SkyeFire
    • May 9, 2018 at 4:57 PM
    • KUKA Robot Forum
  • self-developed UDP server can receive xml file from robot, but cannot send xml successfully
    • ArthurWong
    • August 4, 2021 at 7:01 AM
    • KUKA Robot Forum
  • KUKA KRC4
  • x11
