7th Axis Servo Gripper
  • TheKetteringKid
  • May 1, 2025 at 5:02 PM
  • TheKetteringKid
    7
    I am working on a project that uses a servo gripper for a palletizing process. I have no experience with a servo gripper only pneumatic. I have setup the servo gripper to be G2 A1. I am using extended axis control and multi-group motion. I am working on roboguide and have noticed points I make (using PRs) move both motion groups. Is there a way to not move both motion groups? For different material I will have a different servo position and I do not want unique points for all the clearance and prep moves for each servo position... I might be asking how to not use multip group motion is certain programs.
  • Nation
    Typical Robot Error
    551
    1,932
    • May 1, 2025 at 5:16 PM
    • Best Answer
    Modify the Group Mask in details of the program to use only the arm motion group.
  • jstolaruk
    16
    189
    • May 1, 2025 at 7:43 PM
    I make my robot gripper extended axis part of group 1; I advise the same based on your description. Even have you have to have different J7 values for different parts at the same pick and place points, its still easier.
    Edited once, last by jstolaruk (May 1, 2025 at 7:50 PM).
  • TheKetteringKid May 2, 2025 at 3:37 PM
    Selected a post as the best answer.
  • TheKetteringKid
    7
    • May 2, 2025 at 3:38 PM
    The mask was exactly what I needed. Thanks Nation
Similar Threads
  • 7th axis control gripper and Coordinated motion
    • Napster_matta
    • January 7, 2025 at 10:18 AM
    • Fanuc Robot Forum
  • Adding External Axis non Fanuc
    • jasiekxl
    • January 22, 2024 at 5:14 PM
    • Fanuc Robot Forum
  • delay of movement when switching motion groups
    • Famous_Fella
    • October 12, 2022 at 9:53 AM
    • Fanuc Robot Forum
