I have recently purchased a used KR6 R900 Sixx with a KRC4 smallsize CCU. The control cabinet seems to be working fine, I was able to make backups and get WorkVisual connected, but so far I have been unable to get a connection to the robot. I've checked the X20/X30 and X21/X31 cables, and every wire has continuity between its respective pins so I don't think the cable is broken.
Inside WorkVisual I've downloaded the project from the cabinet and there is a second _Tray controller that is greyed out. I cannot seem to remove it in any way, I'm wondering if this is causing some of my problems and if there is a way to change the configuration for the cell to remove it? The company I purchased it from were using it as a parts loader I believe, and I guess it was interfacing with some other controller.
I have attached the error messages I see, I imagine KSS00272 (No robot number programmed) and KSS00276 (Machine data do not match robot type) might be the most relevant and might be causing the other issues? I also assume the Ethercat issues are a result of the _Tray controller not being available.
I tried setting $robtrafo[] value to $trafoname[] to try and fix the machine data not matching robot error but it didn't appear to do anything.
Here are the pictures of the logs, the WorkVisual project, and any other screens/images I figured might be useful
If anyone can point me in the right direction as to getting the robot arm itself to function correctly, I'd appreciate it.
