4-Axis Robots and WJNT
  • EnergyAddict
  • April 30, 2025 at 3:58 PM
  • EnergyAddict
    45
    133
    Ok. So I inherited some robot code, on a few M410s. The Original Programmer has some linear moves, that he sometimes uses a WJNT with and sometimes not. It's the exact same path, and point, and speed, etc. the only difference is the WJNT see below:
      #:  IF (some status is met) THEN ;
      #:L PR[99:VARPOS] 1000mm/sec CR25 Wjnt    ;
      #:  ELSE ;
      #:L PR[99:VARPOS] 1000mm/sec CR25    ;
      #:  ENDIF ;
    The Question is, with these being 410s (4-Axis robots) what really is the difference that a WJNT would do to the move, and why WOULDN'T you ALWAYS use a WJNT?
    From what I'm told, this may have been added because at one point J4 would execute this move during a certain case (Without WJNT) and would end up winding itself up and causing an axis limit error.
  • Sergei Troizky
    70
    658
    • April 30, 2025 at 4:52 PM
    Quote from EnergyAddict
    That's right. This is the only reason to use WJNT, regardless of the number of axes.
  • EnergyAddict
    45
    133
    • April 30, 2025 at 5:05 PM
    Is there any reason you wouldn't want to use a WJNT move? specifically with a 4 axis robot?
  • Sergei Troizky
    70
    658
    • April 30, 2025 at 5:30 PM
    Wjnt by definition affects axes 4 and up. On 5- or 6-axis robot, the path becomes unpredictable (though repeatable), which may be a problem in tight space.
    With 4-axis robot I cannot imagine a reason for not using it.
