KR C5 IO mapping in backup files
  • Mateusz.MK
  • April 29, 2025 at 3:02 PM
  • Mateusz.MK
    7
    Is it possible to find the IOmaping configuration data somewhere in the archive file ?
    In Work Visual it's not a problem but I can't find it in the archive file.
  • SkyeFire
    1,060
    9,456
    • April 29, 2025 at 3:14 PM
    I vaguely recall that the I/O mapping for KSS 8 is distributed among a number of XML files. But I don't think I ever tested that.
    One quick way to check would be to make an Archive, then make a small I/O mapping change, and make another Archive. Then run the two Archives through a comparator like KDIFF or Beyond Compare. The files that show differences would be the places to dig in further.
  • MOM
    176
    7
    1,424
    • April 29, 2025 at 4:39 PM
    The name should be KRC_IO.xml and can be found in the directory
    KRC\ROBOTER\Config\User\Common\
  • panic mode
    1,296
    13,133
    • April 29, 2025 at 6:19 PM
    1. open registry and check the name of active project ("CurrentProjectName")
    2. go to C\KRC\User\ProjectRoot and open WoV project with name you found in previous step
Similar Threads
  • Changed Robot Type in Roboguide
    • RoboAd
    • November 28, 2024 at 8:16 AM
    • Fanuc Robot Forum
  • Start with a kuka Robot
    • wag_FFU
    • June 5, 2024 at 9:09 AM
    • KUKA Robot Forum
  • Buy old robot, programing, 2D/3D file, first buy
    • Swebot
    • October 14, 2021 at 2:34 AM
    • ABB Robot Forum
  • Creating EtherCAT I/O connections through WorkVisual
    • RobotProgrammer
    • June 2, 2017 at 8:38 PM
    • KUKA LBR IIWA
  • Creating and mapping safety I/O
    • SkyeFire
    • February 21, 2022 at 6:06 PM
    • ABB Robot Forum
