Hi there,
I have a FANUC robot with one camera mounted on the gripper.
There are two drawers (left and right of the robot), where I can insert the same grid frame to calibrate the UFRAMEs. This works perfectly with the IRVision Utilities.
I also nee the perfect UTOOL of the camera, because I need to navigate above the same position relative to each UFRAME. But my camera has a small tilt and manually I tried but I cannot find the perfect TCP setting for the camera.
If I try to set the UTOOL with the same Utility after calibrating the UFRAME than the FANUC tells me, that this is only possible with a fixed mounted camera.
Any ideas what I can do? Is there an option I need to buy? Is there any option to do this at all?
