Execute (run) a code even robot on error
  • MoEL
  • April 21, 2025 at 6:12 PM
  • MoEL
    109
    I need to modify some variables in many robots to be able to jog them, these robots are on error mode because the PLC is not connected.
    So I wanted to modify thes variables:
      1:  ! Set Enable UI Signals to False ;
      2:  $OPWORKS.$UOP_DISABLE=1 ;
      5:  ! Set specified variables to 0 ;
      6:  $PNSF_SET.$BY_PWFAIL=0 ;
      7:  $PNSF_SET.$BY_PLCCON=0 ;
      8:  $PNSF_SET.$BY_PLCRUN=0 ;
      9:  $PNSF_SET.$BY_T1ONLY=0 ;
      3:  ! DCS Profinet Bypass(2) Enable(1) ;
      4:  $PNSF_SET.$MODE=2 ;
    I created a program but I can't run it because of the robots on error, is there a way to modify this variable by some program or script?
    Thank you very much
  • vipinpunneri
    137
    • April 21, 2025 at 6:32 PM
    You can use the same logic and run as a BG Logic.
    Thanks regards<br />Vipin..
Similar Threads
  • Analog Input Value from SPS loop
    • RoboMan3000
    • March 18, 2025 at 11:31 PM
    • KUKA Robot Forum
  • difference between K-IDE and KRTERM
    • abedoof
    • January 20, 2025 at 5:31 PM
    • Kawasaki Robot Forum
  • Auto Select Program on Start Up?
    • dlanhart
    • May 16, 2024 at 12:15 AM
  • FILE-008 when running Karel file
    • coffeeBean
    • October 11, 2024 at 6:01 PM
    • Fanuc Robot Forum
  • Debugging SemiStatic modules -- some notes
    • SkyeFire
    • March 30, 2022 at 7:42 PM
    • ABB Robot Forum
  • Program stuck executing motion command (LIN_REL), but robot is not moving.
    • RoboterEST
    • July 15, 2021 at 8:50 AM
    • KUKA Robot Forum
