WorkVisual, how to directly map an array to the inputs
  • Alky_robot
  • April 16, 2025 at 4:15 PM
  • Alky_robot
    Good morning, I have a problem: I need to map an indexed list (array) of bool into a series of inputs.
    something like this:
    DECL BOOL es[10]
    SIGNAL es[1] $IN[1]
    SIGNAL es[2] $IN[2]
    SIGNAL es[3] $IN[3]
    Can someone tell me how to do it, thank you!!
  • SkyeFire April 16, 2025 at 4:38 PM
    Approved the thread.
  • hermann
    412
    2,629
    • April 16, 2025 at 4:43 PM
    Not possible.
    SkyeFire
    1,061
    9,463
    • April 16, 2025 at 7:33 PM
    Not possible directly.
    You could create a SIGNAL of X bits, then manipulate it on a per-bit basis:
    SIGNAL oMyOutPut $OUT[1] TO $OUT[32]
    DECL BOOL bMyArray[32]
    FOR _nIndex = 1 TO 32
      $OUT[_nIndex] = bMyArray[_nIndex]
    ENDFOR
  • panic mode
    1,298
    13,141
    • April 16, 2025 at 9:10 PM
    yup...
    there is a function
    GET_SIG_INF (CHAR SIGNAME[24]:IN)
    but i have not found SET_SIG_INF or similar...
    you could write something like
    SIGNAL es $IN[1] to $IN[4]
    SIGNAL fr $IN[5] to $IN[8]
    SIGNAL de $IN[9] to $IN[12]
    SIGNAL jp $IN[33] to $IN[36]
    etc
    and read it like
    $OUT[666]=Get_Signal_Bit(es,2)
    DEFFCT BOOL Get_Signal_Bit(sig_value:in,bit_pos:in)
      DECL INT sig_name, bit_pos, temp
      SWITCH bit_pos
         CASE 1
            temp = sig_value B_AND 1
         CASE 2
            temp = sig_value B_AND 2
         CASE 3
            temp = sig_value B_AND 4
         CASE 4
            temp = sig_value B_AND 8
          DEFAULT
             MsgQuit("Nope...")
         ENDSWITCH
      RETURN temp>0
    ENDFCT
  • Alky_robot
    • April 17, 2025 at 8:51 AM
    thx:thumbs_up:
  • gklpsn
    7
    • April 17, 2025 at 11:03 AM
    i think u can not do like these, but u can do this
    at config.dat decl itDECL BOOL MY_ARRAY[10]
    MY_ARRAY[1]=FALSE
    MY_ARRAY[2]=FALSE
    MY_ARRAY[3]=FALSE
    MY_ARRAY[4]=FALSE
    MY_ARRAY[5]=FALSE
    MY_ARRAY[6]=FALSE
    MY_ARRAY[7]=FALSE
    MY_ARRAY[8]=FALSE
    MY_ARRAY[9]=FALSE
    MY_ARRAY[10]=FALSE
    create new empty sps.sub
    FOR I=1 TO 10
    MY_ARRAY[I]=$IN[STARTING_OFFSET_BIT_NUMBER+ I -1]
  • input
