Does Setting $REF_DONE to TRUE Affect Mastering/Position Data Immediately?
  • gmumaugh
  • April 14, 2025 at 5:18 PM
  • gmumaugh
    13
    63
    Hey all, apologies if this question is too similar to some of the other ones I saw, but I couldn't glean a clear answer from them. I'm setting up some SR-6iAs on R-30iB Compact Plus controllers, but it's been a while since I've had to set up a Fanuc. The factory mastering data was good, but I was getting a warning on one robot that the reference position for the quick mastering hadn't been set. The robot was not at its zero position, which I should have done just to be safe.
    Since I didn't need to actually perform any mastering, I ensured $REF_POS were all at 0°, then copied the values from $MASTER_COUN to $REF_COUNT, then set $REF_DONE to TRUE. I figured since I wasn't going through the Master/Cal menu, it wouldn't actually perform the mastering at reference position. However, after checking my position values, J4 was sitting around 700 deg, mistake number 2 was not carefully checking the position values before starting this procedure. I restored the sysmast.sv file from an earlier backup, before I ever touched mastering, but J4 was still showing an extremely high position value.
    I decided to check the current pulse counts, and J4 had a value of -16001079, which does actually seem accurate. So is it possible that the mastering is actually okay, and someone just decided to swing J4 around a couple times? Does setting $REF_DONE to true immediately perform the reference mastering? Either way, in order to be safe I am going to redo this procedure with the robot physically at its 0° position.
  • gmumaugh April 14, 2025 at 5:52 PM
    Changed the title of the thread from “Does Setting $REF_POS to TRUE Affect Mastering/Position Data Immediately?” to “Does Setting $REF_DONE to TRUE Affect Mastering/Position Data Immediately?”.
    DS186
    200
    1,067
    • April 14, 2025 at 5:55 PM
    The reference position has nothing to do with the Quick Mastering procedure itself. However, you have to set a Quick Mastering reference position before Quick Mastering is necessary.
    By default the reference position is set to the zero position of the robot. But you can use any other position if you want. In that case you should put marks in the axes to be able to verify the position.
  • mastering
  • Reference Position
