  3. Simulation Systems
  4. other Systems and general Simulation Discussions
MotoSimEG-VRC to Visual Components 4.10 connectivity plugin.
  • mil3k
  • April 3, 2025 at 2:15 PM
  • mil3k
    15
    71
    Did anyone manage to connect MotoSim to Visual Components 4.10 by use of VC connectivity plugin?
    I followed this video: https://youtu.be/eW7q9kPp5es from the VC Academy but the connectivity tab didn't show on my MotoSim2023SP1 at Win 11PRO 24H2. I repeat the same process on another PC with Win7Pro with MotoSim2019SP1 with the same result. I suppose the problem is wrong path to the plugin folder.
    massula
    200
    8
    1,421
    • April 3, 2025 at 6:58 PM
    Did a quick test here, with MotoSim 2023SP1 running on Windows 10 Pro and didn't worked as well, even copying the contents of the plugin inside MotoSim Documents folder manually, as indicated in the .bat file.
  • mil3k
    15
    71
    • April 6, 2025 at 8:27 PM
    The problem was solved by running MotoSim as an Administrator. I never run it in that mode and MotoSim didn't create a key: HKEY_CLASSES_ROOT\MotoSimEG_VCR.Application in the windows registry. There was only: HKEY_CLASSES_ROOT\MotoSimEG_VCR.Documents, before I run it as and Administrator.
    Cause: Missing entry in Windows Register: HKEY_CLASSES_ROOT\MotoSimEG_VCR.Application
    Solution: Run MotoSim at least once as an administrator.
    Display Spoiler
    1. Insert the hardware key of MotoSimEG-VRC effective.
    2. Right-Click on the MotoSimEG-VRC icon and choose “Run this program as an Administrator”.
    3. Registy registration is automatically performed at a start-up, and the following key is created in the registry: HKEY_CLASSES_ROOT\MotoSimEG_VCR.Application
    Install the plug-in:
    Display Spoiler
    1. Run VC-MotoSim-Installer-x64.bat. This action should copy files to the correct location and return an error. That’s fine
    2. Right-click at VC-MotoSim-Installer-x64 and choose “Run this program as an Administrator”. This time registration should be successful as per video.
    Note: In the Visual Components Premium 4.10 OLP Yaskawa Pulse Solver is no longer in the Postprocesses tab as per video, but in the next tab: Tools
    Edited once, last by mil3k (April 6, 2025 at 8:33 PM).
  • Motosim
  • visualcomponents
  • MotoSimEG-VRC
