SPOT Instruction Parameters
  • Cesar_Ticante
  • March 27, 2025 at 5:55 PM
  • Cesar_Ticante
    Hi. I have a robot which performs Spot welding operations. I am new to this kind of operation so I'm trying to understand how does it work. So, I took a peak into one of the programs for welding and I encountered the SPOT instruction in one of the lines. It goes like this:
    33:	L P[11] 800mm/sec CNT100
      :	SPOT[SD=10, P=4, t=2.9, S=7, ED=10]
    So, I understand that the parameters have the following meaning:
    • SD = Start Distance Schedule
    • P = Pressure number
    • t = thickness value in mm
    • S = Schedule number
    • ED = End Distance schedule
    Those meanings come from the TeachPendant in Roboguide, I got to read the SpotTool Operator's manual and the parameters are different from the ones I have in the TP, hence my question.
    Howerver, I'm unable to find where those "schedules" are configured. I've tried the following menus:
    • "MENU -> SETUP -> Spot Equip"
    • "MENU -> SETUP -> Spot Adv fctns"
    But I just can't find that configuration. Could you help me find out the route to configure those schedules, please?
    Edited once, last by Cesar_Ticante (March 27, 2025 at 6:16 PM).
  • massula March 27, 2025 at 5:56 PM
    Approved the thread.
  • ssaul
    8
    52
    • March 28, 2025 at 6:12 AM
    SD, ED, and P can be found on the "data" key on the teach pendant.
    t = thickness value in mm, which you configure in menu-setup-servogun/thickness check.
    And finally, "S = Schedule number" is generally managed using the welding equipment's interface.
  • Cesar_Ticante
    • March 31, 2025 at 3:35 PM
    Quote from ssaul
    Thanks a lot, Saul. So, if my understanding is correct, every time I have a SPOT Instruction, the number for "S=" references the schedule number in my welding controller, right?
    For example, this line:
    If I wish to know the parameters for this spot welding, I should check the Schedule #7 in the welding equipment's interface, right?
    Thanks in advance!
  • ssaul
    8
    52
    • March 31, 2025 at 10:29 PM
    Quote from Cesar_Ticante
    Thanks in advanc
    that's how it is
Similar Threads
  • Linking a variable to Group Output
    • cpanchal
    • August 6, 2024 at 4:51 PM
    • ABB Robot Forum
  • Custom Instruction in TPE editor
    • KaiF
    • January 18, 2023 at 9:55 AM
    • Fanuc Robot Forum
  • Details of a Kawasaki Move command
    • Shearzy
    • February 24, 2021 at 4:46 PM
    • Kawasaki Robot Forum
  • Spottool+
  • spot welding
