Fanuc CRX 10iA/L High Speed Mode
  • OB F-CRX
  • March 27, 2025 at 4:41 PM
  • OB F-CRX
    7
    We are working on a project to fence in one of our Fanuc CRX 10iA/L, and run at higher speeds than the current limit. I have always struggled to get support on the CRX robots, locally.
    What is the recommended, simplest method for doing this? We are not using an area scanner, simply physically enclosing. Can I just disable the contact stop function in the DCS settings, then adjust the max speed limit in that same screen? Will it affect the auto status check function?
    Any help is appreciated as this is a time sensitive project.
    thank you
  • DS186
    200
    1,066
    • March 28, 2025 at 10:08 AM
    Check this thread for information about enabling the high speed mode on a CRX robot.
    Post
    RE: Fanuc crx HIGH SPEED mode
    It is going to be under setup Under the collabo Robot setup Tab. You will have to disable the collaborative mode along with some other settings
    ASUA1
    December 23, 2024 at 3:58 PM
  • collaborative
  • contact stop
  • auto status check
  • fanuc crx10ia
  • Fanuc crx HIGH SPEED mode
