Good morning all,
every time I send project from WV to robot and after I select program I have error on the robot KSS02801
Robot KRC5
Las 8.7.6 hf1
If somebody knows what could create this alarm please write on this post.
Thank you
Good morning all,
Robot KRC5
Las 8.7.6 hf1
Thank you
you have some problems in the SPS program.
If you wrote the code yourself in this program, check the code first. Or you can upload the old one (before the problem occurred) and the robot will work.
The exclamation mark on the S key also indicates that there is a problem in the SPS.
Yes, I have some modyfication in sps but it is in user plc
Press S at the top of the robot controller and try start the SPS. You can also do this by pressing select on SPS program. If it still doesn't work, there is definitely some kind of error in the SPS code.
I remove my modyfication in sps but after restart submit still have exclamation mark which is strange because now its default.
Tomorrow I will change it with one from old backup.
Thank you for your help
do not write code in SPS.SUB...
put all of your additions in a separate module such as MySubmit.SRC and just call it from user section of SPS.SUB after you are done with testing and debugging of your module.
