  4. Mitsubishi Robot Forum
Issue with Camera and Robot Coordinate Alignment – RV-4FL-D with CR750-D Controller
  • A.Mekni
  • March 24, 2025 at 11:29 AM
  • A.Mekni
    13
    Hello everyone,
    I am working on a project with a Mitsubishi RV-4FL-D robot and a CR750-D controller. In this setup, I use a Cognex camera mounted on the gripper to capture an image and extract the X and Y coordinates of an object. These coordinates are then sent to the robot, where I assign them to a position as follows:
    P1.x = Xcam
    P1.y = Ycam
    I have already performed the camera calibration and created a base coordinate system, ensuring that both are aligned. However, I have noticed that when I compare the same point from the robot’s perspective and the camera’s perspective, the coordinates do not match.
    I am trying to understand what might be causing this misalignment. Could it be related to:
    • Incorrect calibration of the camera or base?
    • A transformation that needs to be applied to the camera coordinates before sending them to the robot?
    • An issue with the reference frame in the robot?
    Any guidance or suggestions would be greatly appreciated!
    Thank you in advance.
    Best regards,
  • COGNEX
  • Mitsubishi Robot
  • Base calibration
