I'm continuously encountering the following error message in KUKA.Sim:
Unhandled exception on starting the simulation.
The data type MAXTOOL used in $MACHINE (line 617, column 6) could not be found.
This issue occurs even in completely new, fresh projects whenever I insert a new robot arm, even without any code associated with the robot. The problem first appeared after uploading a program to a real KRC4 controller. The original robot arm connected to this controller continues to function correctly in simulation. However, every new project I open afterward exhibits the same error repeatedly.
I have already reinstalled the software entirely, but this did not resolve the problem.
Has anyone encountered a similar issue before, and if so, could you please advise how to solve this error?
