Hi all, I need to replace the battery in my Comau controller.
It has a 16.8v Ni-cd pack in at the moment, is there anything stopping me replacing it with similar Li-ion? They're easier to find and cheaper.
as far as i am aware the issue to solve is if charging is compatible or not and if it can be replaced. cells using different chemistry use different charging method.
You're right, might not be worth the hassle. I've found some ni-cd packs on aliexpress, should do the trick.
