I have a robot that I can not get to start through the PLC. The program select mode is Style. Production Start Method is UOP. I know other is used most often but this is the settings that we use on all of our other robots. Then through the system/config screen it is setup to Remote and the UOP assignment is Full.
When I have the Enable UI signals set to false the alarms clear, the money symbol in the Production box in the top of the screen appears and UI[6]: Start lights up through an external button we want to start the robot with.
When I turn the UI signals turned to True I receive an IMSTP alarm. I imagine this is caused by the PLC.
Does is look like everything on the robot side is correct?
