X804 mfc2
  • m.dinio
  • March 8, 2025 at 5:04 PM
  • m.dinio
    61
    Hi
    I using kuka mfc2 x804 ethernet , but when windows hibrnated , after startup network is disbale ,after that i must cold booting to start network again, how can i solve this problem??:loudly_crying_face:
  • m.dinio
    61
    • March 9, 2025 at 5:10 PM
    Please help me to solve it
    SkyeFire
    1,052
    9,429
    • March 10, 2025 at 12:41 AM
    Quote from m.dinio
    MFC2? What model controller? I assume KRC2, but pre-ed2005?
    "Network is disabled" -- what does this mean? What tests have you performed?
  • hermann
    407
    2,612
    • March 10, 2025 at 8:33 AM
    Make cold boot persistent. There is a registry file in 'tools' directory somewhere under the krc directory on drive c:.
  • m.dinio
    61
    • March 10, 2025 at 9:58 AM
    Quote from SkyeFire
    Kuka krc2 before 2005.when i cold booting , i can ping it from another network,but after hibernate i can't.
    I use RSI with x804 .
    SkyeFire
    1,052
    9,429
    • March 10, 2025 at 8:29 PM
    Quote from m.dinio
    That is not an approved usage. I assume you have it configured to use the KUKA.Router program for software routing in Windows? And this must be RSI-XML, as opposed to "vanilla" RSI.
    Is RSI running when you hibernate the KRC? Is the RSI port open?
    I assume you're trying to ping the actual NIC IP, rather than the specific RSI port? It is quite odd that the NIC would not recover after a Warm Start. Is it possible to ping or make connections outbound from the KRC?
  • m.dinio
    61
    • March 12, 2025 at 2:02 PM
    RSI port is open when when i hibernate the KRC.
    SkyeFire
    1,052
    9,429
    • March 12, 2025 at 2:48 PM
    Quote from m.dinio
    I have a hunch that might be part of the problem. I suggest experimenting with hibernating the KRC with the RSI port closed and see if that prevents the problem.
    If that works, my first thought is to add an Interrupt or some SPS code that can detect an impending Hibernation and close the RSI port. I don't recall offhand if there's a system variable that trips when the KRC is performing a controlled shutdown, though. You might have to close the RSI on errors or on program halts, and include methods to re-open RSI on resume.
  • m.dinio
    61
    • March 12, 2025 at 3:03 PM
    Quote from SkyeFire
    ok , i will do it ,thanks
  • MFC
