I am experiencing a very strange issue with a robot I have. The robot is a KR5 with a KRC4 controller running KSS 8.5.7.
When I command movement on the 4th axis, it rotates but then starts making a whistling sound. After rotating for a certain period, the motor stops with a "Gear torque" error. Along with the sound, there is a high-frequency vibration. Even when the motor is not rotating, this vibration persists as soon as power is applied.
At first, I suspected a mechanical issue, but when I removed the wrist, I realized that the same situation occurs on axes 4, 5, and 6. However, the whistling sound is only present on the 4th axis motor, while the others only exhibit high-frequency vibration.
All motor brakes function correctly, and the measured cable values appear normal.
The KSP module for these axes works fine in other robots.
I checked the connectors, motor cables, and encoder cables one by one but not found abnormality.
Motors have been tested and are in good condition.
The RDW is fine.
The wrist is fine, yet the motors vibrate when idle.
Despite all values appearing normal, I suspect internal cables, but honestly, I'm stuck at this point. The probability of all three motor cables failing at the same time doesn’t seem make sense.
Does anyone have any ideas?
