Hi.
I have a problem with the air motor on the IRB 5500 robot applicator.
The errors are:
- A1AtomRS:Val hi (when you set the value it always exceeds it and does not stop at the required value...in + or in -)
- A1Atom:No signal
I have 4 such turbines.
When I installed the new turbine/air motor, it worked normally.
Does anyone have a suggestion/solution?
Thanks in advance. Best regards
