pausing a program
  • jaiiyer
  • February 25, 2025 at 8:51 PM
  • jaiiyer
    16
    91
    Is there any system variable other than $move_enable or $drives_off to pause the program execution? Like not stopping the drives but just pausing the program pointer. I usually define an interrupt and then do the following
    INTERRUPT DECL 5 WHEN diPause==TRUE DO Pause()
    INTERRUPT ON 5
    DEF Pause()
    brake
    wait for NOT diPause
    END
    I wanted to know if there is some other way of achieving this. Thank you.
    SkyeFire
    1,061
    9,461
    • February 25, 2025 at 10:09 PM
    • Best Answer
    Nothing direct. And dropping $MOVE_ENABLE or $DRIVES_OFF will generate a safety(ish) stop, probably a Cat 1, along with the resulting errors.
    A method that is not very recommended, but sometimes used, is to manipulate $OV_PRO (KSS 5 or older) or $OV_APPL (KSS 8.something). The only real advantage to this is that you could, say, pause the robot on a defined vel/time curve rather than simply flipping between 0% and 100%. Which has come in handy a few times.
    $OV_PRO is not recommended if your KSS has $OV_APPL available, because $OV_PRO can end up in a "custody battle" between your program and the +/- keys on the pendant, which I've had create issues where the value displayed stopped updating properly.
  • jaiiyer February 26, 2025 at 2:30 AM
    Selected a post as the best answer.
  • jaiiyer
    16
    91
    • February 26, 2025 at 2:31 AM
    Thanks a lot SkyeFire BTW i am amazed at how much you and panic mode knows.
    Edited once, last by jaiiyer (February 26, 2025 at 2:40 AM).
  • jaiiyer
    16
    91
    • March 1, 2025 at 5:59 PM
    Quote from SkyeFire
    A question just popped up in my mind... so is this different than using BAS(#VEL_PTP, xxx) and/or BAS(#VEL_CP,xx) commands?
  • panic mode
    1,297
    13,141
    • March 3, 2025 at 2:16 AM
    BAS(#VEL_xx,value) sets programmed velocity. this is MEANT to set velocity along programmed path.
    $OV_PRO is a program velocity override. this is manual control for operator so that he/she can override (throttle the speed down) as needed when testing program.
    SkyeFire
    1,061
    9,461
    • March 3, 2025 at 2:42 PM
    If you're familiar with CNC machines, $OV_PRO and $OV_APPL are like the "feed rate overrides".
    Basically, the speed the robot physically moves at will be the point speed (set by those BAS calls, or by direct setting of the system variables) multiplied by the % of $OV_PRO and %OV_APPL.
    So, a LIN motion programmed at 1m/s will only achieve 500mm/s if $OV_PRO or $OV_APPL is set to 50. It's also serial multiplication, so if both $OV_PRO and $OV_APPL are set to 50, then you'll only get 250mm/s (1m/s * 50% * 50%).
Similar Threads
  • Submit interpreter to stop 3D printer extruder
    • akaaschool
    • October 31, 2024 at 6:48 PM
    • KUKA Robot Forum
  • External Deadman via Robot I/O
    • Ace's_Robot_Delivery
    • February 19, 2024 at 4:43 PM
    • Fanuc Robot Forum
  • Stop at predetermined part# on pallet?
    • Krash
    • June 7, 2023 at 4:25 AM
    • Kawasaki Robot Forum
  • multi-threaded program in kuka KRC4 robot (KSS 8.3)
    • postek
    • March 13, 2023 at 1:08 PM
    • KUKA Robot Forum
  • Pausing a programme in AUT mode
    • M J
    • January 20, 2023 at 3:23 PM
    • KUKA Robot Forum
  • Local registers from software version v9.40
    • DS186
    • May 23, 2022 at 11:01 PM
    • Fanuc Robot Forum
  • Pausing Program in Auto Mode
    • Searchligt_1
    • June 9, 2022 at 8:14 PM
    • Fanuc Robot Forum
  • " INTP-311 (MODIF_TCP, 84) Uninitialized data is used"
    • i_robot72
    • September 30, 2021 at 9:06 AM
    • Fanuc Robot Forum
  • Kuka Ready2_animate - Str value invalid
    • schub
    • April 27, 2021 at 2:44 PM
    • KUKA Robot Forum
