I just inserted a AB3609-C board (Profinet) into the riser card CPU rack.
I booted into maintenance mode, set the security level to maintenance, and found the board in OPTION BOARD menu and set it to "Used".
I clicked through the setup with IO allocation, didn't change anything here.
But how do I change the IP of it? It is my understanding that it has a seperate IP address than the robot controller, am I wrong here?
How am I supposed to connect remotely using this card? Currently, I have an ethernet cable in the LAN port in the controller and into the wall, and I can connect from my PC on the domain network. Should I put that cable into the profinet port instead?
I apologize if this is a stupid question, I am completely new to this.
Best regards!
