I am currently using a Kawasaki CP-180L robot with an E Controller.
How do I configure the Profinet I/O addresses so that the main I/O of the robot is not interrupted? For example, if Output 1 is used for turning on a motor, but I want Output 1 to be the starting address for Profinet communication, how can I set this up?
I am communicating with the PLC, and it works, but when the robot tries to send Output 1 to the PLC, it is already being used for turning on the motor. I have already allocated the signal for the slave, and the table shows that it starts from 1001, but in actual monitoring, it still shows as 1. Why is this happening, and how can I fix it?
Thank you for your responses and help!
