Kuka SYS-X44 Error
  • Mustafa Cem
  • February 18, 2025 at 5:31 AM
  • Mustafa Cem
    Hello all
    I found you through this forum and I have a problem with my kuka robot.
    My robot gives the error in the picture after working for 2-3 hours. When I re-install it, it works for another 2-3 hours and then goes back to the same error.
    I changed the cables from the cabin to the terminal from xx44 and tested it and it works. It seems that this is not the problem.
    Error is ethercat bus error Device EL6692 EtherCAT bridge terminal (Secondary(
    Error on reading/writing SYS-X44
    I added the error photos.. thanks allN6PkTSrp
  • Roland Keller February 18, 2025 at 8:36 AM
    Approved the thread.
  • SkyeFire February 18, 2025 at 2:58 PM
    Moved the thread from forum General Discussion of Industrial Robots Only to forum KUKA Robot Forum.
  • panic mode
    1,296
    13,136
    • February 18, 2025 at 3:53 PM
    what picture?
  • ethercat bridge
