  4. ABB Robot Forum
how to pause i/o ?
  • irham
  • February 17, 2025 at 3:56 AM
  • irham
    8
    Hello Everyone,
    We are using ABB IRB 6640 and IRC5 Controller, we are using SetDO to control some external device. But There is one problem, when i pressed the pause button on TP ( or release the deadman switch in teach cycle) in the middle of routine/program the Signal not change to "0". How to make the signal goes "0" when pause and become "1" again after the start button was pressed and continue in last command. the device signal become "1" again after it meet the next SetDO that valued "1".
    Thanks,
    Irham
  • saberlars
    Robot, beyond Human..
    22
    239
    • February 17, 2025 at 9:20 AM
    Check "Cross Connection"
    or
    You can Simulate(ignore) that Output signal while manual TP operation.
    ABB, FANUC, Hyundai, Kawasaki
  • SomeTekk
    17
    202
    • February 17, 2025 at 10:50 AM
    Look into Event Routines
  • Jose Henrique
    49
    • February 22, 2025 at 3:36 PM
    In my opinion, the better way to do is use a cross connection using an "AND" like:
    -Res "SignalOutput" -Act1 "Comand" -Oper1 "AND" -Act2 "CycleOn"
    when the cycle goes off your signal output goes off.
    when the cycle goes on, it depends if your comand is on or off.
    Edited once, last by Jose Henrique (February 22, 2025 at 3:43 PM).
Similar Threads
  • Nachi FD11 Controller External Start Issue
    • kevilay
    • October 15, 2021 at 11:56 PM
    • Nachi Robots
  • Touch Sense Program W/O Macros
    • BMGN01
    • December 16, 2024 at 11:35 AM
    • Yaskawa Motoman Robot Forum
  • Help With Pause Points From
    • AustinC03
    • August 2, 2024 at 10:29 PM
    • Fanuc Robot Forum
  • Issue with $OV_PRO Command in Robot Program
    • AD3MIN
    • March 15, 2024 at 12:04 PM
    • KUKA Robot Forum
  • Alarm Severity Ethernet IP Scanner Advanced
    • Paolo
    • November 28, 2023 at 2:00 PM
    • Fanuc Robot Forum
  • instruction pause
    • yusuf
    • November 24, 2023 at 7:50 PM
  • how to stop the robot just befor strart welding a point from an HMI
    • yusuf
    • October 12, 2023 at 8:25 PM
  • KRC4 touchup disable
    • markop
    • September 24, 2013 at 9:36 AM
    • KUKA Robot Forum
  • Lincoln Powerwave 455m error when I attempt to feed wire
    • EPeters1
    • November 3, 2021 at 1:05 PM
    • Fanuc Robot Forum
  • pause
  • I/O configuration
