Hello everyone!
I have encountered a problem with constant rebooting of the E43 controller with the ZD250S robot. I will describe the situation in more detail.
The problem started suddenly a couple of days ago. The robot was working properly, when suddenly it just turned off and started rebooting constantly. That is, it starts to turn on and immediately turns off. I will say right away that the X9 connector on the 1TR board has factory jumpers.
Just in case, I decided to blow out the dust from the controller and the following happened: the controller turned on, worked for about 5 minutes and immediately turned off. And again the reboot situation repeated itself. After repeated blowing, nothing changed.
I tried to pull out the I / O and Fieldbus boards, leaving only 1VA and 1TR, but this did not help. The power supply voltage is normal.
I suspect a malfunction in the 1TR board. There is a second controller from which I can try to re-plug the board, but since this is a controller in production, I am afraid that I can damage the board.
The strangest thing is that it still worked for 5 minutes after blowing.
What else can be checked and what is the potential problem it can be?
I only have an old backup of the robot, but if necessary, I will post it.
