How to move the tool to the desired height
  • Jiial
  • February 10, 2025 at 2:11 PM
  • Jiial
    7
    What command can I use to move the robot's tool straight up to the desired height?
  • k1ng
    • February 10, 2025 at 2:43 PM
    You could do something like this. It reads the current position of the robot, and moves it to a height of -300. Change it depending on your needs.
    I'm using Reltool, since I want to not go straight up, but w/ the current orientation.
    The For-Loop is just to ensure the height is reached, since the Z-Value isn't exactly the height if the tool is at a slope, and with every iteration it gets closer to reaching the desired height.
        FOR HeightReached FROM 1 TO 5 DO
           pTempHeight:=CRobT(\Tool:=tool0\WObj:=wobj0);
           MoveL Reltool(pTempHeight,0,0,(-300+pTempHeight.trans.z)),v1000,fine,tool0\WObj:=wobj0;
       ENDFOR
    Lemster68
    301
    2,489
    Blog Articles
    7
    • February 10, 2025 at 2:54 PM
    k1ng
    That won't work too well on a Motoman robot. 😬
  • TheKetteringKid
    7
    You can do this in a macro for moving in T1 or you could add this to a program for running in auto. Make a position register the current position, then change the Z value to your desired height, then move to that position register.
    PR[??]=LPOS
    PR[??,3]=Desired Height
    L PR[??]
  • k1ng
    • February 10, 2025 at 2:59 PM
    Lemster68 Oh, my mistake. Didn't realize which category the thread was in. :upside_down_face:
    Lemster68
    301
    2,489
    Blog Articles
    7
    • February 10, 2025 at 3:01 PM
    Does no one pay attention to the subforum of which robot it is?
  • 95devils
    235
    8
    1,951
    • February 10, 2025 at 6:40 PM
    Quote from Lemster68
    Lemster68
    Did you say something? :face_with_tongue:
  • 95devils
    235
    8
    1,951
    • February 10, 2025 at 6:45 PM
    Quote from TheKetteringKid
    PR[??]=LPOS
    L PR[??]
    This ain’t a Fanuc sub forum. Use the IMOV instruction. Populate manually or set a Position Variable with amount and direction. If you want to move straight with respect to the tool add the TF coordinate tag to the instruction.
  • WattUp
    7
    96
    • February 10, 2025 at 8:30 PM
    If you want to move up 300mm every time, just use an IMOV with a PVAR set to Z 300.
    If you want to move up to a set height every time no matter where you are, you will need to read current position to a PVAR, edit Z to equal the new height, then move to that PVAR.
  • Robodoc
    56
    7
    1,062
    • February 15, 2025 at 2:22 PM
    shift on the tool frame.
    Just my $0.02
    Robodoc
  • Farhan
    26
    • March 8, 2025 at 5:08 PM
    • #11
    if i have this code. and i want the robot move +Z axis 5cm, how the code could be?
    /JOB
    //NAME HOME
    //POS
    ///NPOS 1,0,0,0,0,0
    ///TOOL 0
    ///POSTYPE PULSE
    ///PULSE
    C00000=92160,0,-103424,-206848,0,0,0
    //INST
    ///DATE 2025/02/28 14:59
    ///COMM Generated using RoboDK
    ///ATTR SC,RW
    ///GROUP1 RB1
    NOP
    'Program generated by RoboDK v
    '5.8.0 for Yaskawa SIA10D on 2
    '8/02/2025 14:59:52
    'Using nominal kinematics.
    'Using Posisi 10x10 (targets w
    'rt base):
    '28.5,561.0,-128.0,0.0,0.0,0.0
    'Tool 2 (Tool Snap 2) should b
    'e close to:
    '132.5,0.0,63.5,90.0,0.0,90.0
    MOVJ C00000 VJ=10.00
    END
  • Robodoc
    56
    7
    1,062
    • March 9, 2025 at 2:06 PM
    • #12
    The code depends on if you want to shift all the time or only some times. If you want to shift all the time use the parallel shift utility to shift the line or lines in your program.
    Robodoc
  • Farhan
    26
    • March 9, 2025 at 5:35 PM
    • #13
    how about if i just want to shift some time?
  • 95devils
    235
    8
    1,951
    • March 9, 2025 at 10:17 PM
    • #14
    Either manually or programmatically set up a position variable for direction and amount. Use the SFTON and SFTOF instructions.
