DCS working sphere?
  • jstolaruk
  • February 7, 2025 at 5:27 PM
  • jstolaruk
    184
    Any ideas on create to have a working sphere? It is to restrict the EOAT from moving to far from a feed-thru on a wall so as not to damage an umbilical cord connected to it.
    I've thought about a cube (working zone diagonal) sized for the sphere interior but that may be too restrictive.
    Or working zone (lines) that kind of crudely creates a sphere.
    I think I'm stuck with the latter.
  • HawkME
    568
    10
    3,268
    • February 8, 2025 at 5:23 PM
    If it is just for machine safety not human safety then you could use a combination of DCS and BG logic.
    DCS could be a less restrictive sized cube, maybe with the corners knocked out by DCS out zones.
    Then you could use BG logic to monitor the sum of squares of the current position and ensure it is below a certain limit or trigger a hold or stop signal.
  • Nation
    Typical Robot Error
    523
    1,902
    • February 10, 2025 at 10:25 PM
    I liked the idea of creating a "poor man's" spherical world zone.
    Here it is:
    /PROG  POORMANS_WZ
    /ATTR
    OWNER        = MNEDITOR;
    COMMENT        = "In Sphere?";
    PROG_SIZE    = 733;
    CREATE        = DATE 25-02-10  TIME 16:20:56;
    MODIFIED    = DATE 25-02-10  TIME 16:20:56;
    FILE_NAME    = ;
    VERSION        = 0;
    LINE_COUNT    = 20;
    MEMORY_SIZE    = 1057;
    PROTECT        = READ_WRITE;
    TCD:  STACK_SIZE    = 0,
         TASK_PRIORITY    = 50,
         TIME_SLICE    = 0,
         BUSY_LAMP_OFF    = 0,
         ABORT_REQUEST    = 0,
         PAUSE_REQUEST    = 0;
    DEFAULT_GROUP    = *,*,*,*,*;
    CONTROL_CODE    = 00000000 00000000;
    LOCAL_REGISTERS    = 0,0,0;
    /APPL
    /MN
      1:  !Sphere Location (World): ;
      2:  ! X,Y,Z: ;
      3:  R[11:Sphere X]=(1431) ;
      4:  R[12:Sphere Y]=(-506)    ;
      5:  R[13:Sphere Z]=(542) ;
      6:  !Sphere Radius: ;
      7:  R[14:Sphere Radius]=(300) ;
      8:  !Current Position of ;
      9:  ! the active TCP in World. ;
     10:  ! X,Y,Z: ;
     11:  R[15:Curpos X]=($SV_INFO[1].$CART_POS[1]) ;
     12:  R[16:Curpos Y]=($SV_INFO[1].$CART_POS[2]) ;
     13:  R[17:Curpos X]=($SV_INFO[1].$CART_POS[3]) ;
     14:  !Calc dist ^2 ;
     15:  R[18:Dist^2]=(((R[11:Sphere X]-R[15:Curpos X])*(R[11:Sphere X]-R[15:Curpos X]))+((R[12:Sphere Y]-R[16:Curpos Y])*(R[12:Sphere Y]-R[16:Curpos Y]))+((R[13:Sphere Z]-R[17:Curpos X])*(R[13:Sphere Z]-R[17:Curpos X]))) ;
     16:  IF (R[18:Dist^2]<(R[14:Sphere Radius]*R[14:Sphere Radius])) THEN ;
     17:  F[1:In Sphere]=(ON) ;
     18:  ELSE ;
     19:  F[1:In Sphere]=(OFF) ;
     20:  ENDIF ;
    /POS
    /END
    I tested it, and it works. I initially tried using local registers to do it, but it looks like background logic does not like them
  • jstolaruk
    184
    • February 11, 2025 at 12:12 AM
    Thanks Nation.
    I'll route the flag to DCS and whack them with a DCS fault if they try jogging the robot so far that it could damage the cable (its a laser, would be expensive to replace, and cause a bunch of downtime).
    -Jeff
Similar Threads
  • Detecting collision in Robogiude and setting DI.
    • STRAW
    • March 31, 2021 at 10:05 AM
    • Fanuc Robot Forum
