welding signal
  • Robotmei
  • February 3, 2025 at 1:08 PM
  • Robotmei
    203
    Hello all,
    KSS 5.6.2 ***** 7th axis: kuka linear unit ***** 8th axis: rotary axis like kuka single-axis positioner KP1-V
    The application of the robot is welding and I want to weld both ends of the pipe, i.e. the head and the bottom, completely 360 degrees. Considering that spiral welding is required at the pipe body, I have set the motor to gearbox ratio higher than the actual value so that I can rotate the pipe synchronously for ten full revolutions.
    I need a uniform weld all the way around the pipe. Currently I hold the robot steady and rotate the part 360 degrees. During the rotation at the beginning and end of the job, the speed of the eighth axis is not constant and as a result the weld isn't uniform.
    is it related to how i must configure my positioner or does it need specefic command for rotation of positioner?
    thanks for any help
  • SkyeFire
    1,060
    9,456
    • February 3, 2025 at 2:50 PM
    Start and stop motions will always have accel/decel, and that will amplify the errors in your $RAT_MOT_AX.
    Simplest approach might be to extend the path beyond the beginning and end of the weld, and program some non-welding lead in/out motions to keep the accel/decel ramps outside the actual weld. This would require controlling the weld signals with TRIGGERs rather than regular output commands.
Similar Threads
  • KRC4 Fronius Weld Settings
    • RoboMan3000
    • November 12, 2024 at 7:51 PM
    • KUKA Robot Forum
  • Converting a robot to arc weld
    • tomcat955
    • February 18, 2024 at 5:55 AM
    • General Discussion of Industrial Robots Only
  • Buying a Kawasaki zx200s with missing cables
    • tomcat955
    • September 20, 2023 at 5:33 AM
    • Kawasaki Robot Forum
  • ABB Arc Supervision problem
    • PaulSola
    • November 8, 2023 at 3:28 PM
    • ABB Robot Forum
  • Kawasaki AS Language Spot Welding
    • panter12
    • May 4, 2023 at 1:55 PM
  • KUKA analog input/outputs: how and why not to use?
    • kiwasuse
    • April 13, 2023 at 1:48 PM
    • KUKA Robot Forum
  • The SPOT time series(OBARA welder)
    • sbfukidr
    • December 10, 2021 at 8:31 PM
    • Fanuc Robot Forum
  • KRC4 Welding error "Bad signal detected with activate control "; Arcsense version 3.3.1
    • rajcs
    • December 8, 2021 at 5:56 PM
    • KUKA Robot Forum
  • Connection between Fronius Tpsi 400 and Yaskawa YRC1000
    • Must4ng379
    • May 6, 2021 at 1:17 PM
    • Yaskawa Motoman Robot Forum
  • Example Robot Program
    • Dodo41
    • April 3, 2021 at 6:37 PM
    • ABB Robot Forum
