Hi, I need help to Change the KRC4
  • annongha
  • February 1, 2025 at 7:55 AM
  • annongha
    Hi guys,
    I'm planning to change the KRC 4.
    I have 2set of KR20R3100.
    I want to change the KRC4.
    Please let me know the precautions and procedure for replacing the KRC4. I am worried that the robot's RDC data or encoder values might be erased. I am also unsure about other potential issues that may arise, so I am leaving this message here. Thank you.
    panic mode
    1,296
    13,136
    • February 1, 2025 at 5:54 PM
    If robot before and after change are same model but different serial number, just connect it and hmi will display message that you need to answer.
    If robot model before and after change is different:
    Connect robot to controller, take project from controller, delete robot then add correct robot model, then deploy and activate project.
Similar Threads
  • Replacing a (v)krc2 + KR210 to a KRC5 + KR120
    • Leon
    • August 27, 2024 at 4:25 PM
    • KUKA Robot Forum
  • Submit interpreter to stop 3D printer extruder
    • akaaschool
    • October 31, 2024 at 6:48 PM
    • KUKA Robot Forum
  • ProfiSafe communication error
    • xlyanyura
    • September 21, 2024 at 3:40 PM
    • KUKA Robot Forum
  • openshowvar periodic timeout issue in KRC4 UL version
    • Eli Dejo
    • December 5, 2022 at 1:35 PM
    • KUKA Robot Forum
  • VKRC2 ed05 for milling. Advice request.
    • marbles
    • December 3, 2021 at 7:20 PM
    • KUKA Robot Forum
  • kr20r3100
