R30iB Pendant Freezing
  • colarosa1
  • January 31, 2025 at 5:39 PM
  • colarosa1
    Have a robot cell that has been running for years that is an LRMate 200iD/7L on a R-30iB controller. Recently the robot can be running for 1 hour or 8 hours and then the motion just stops. When I go to the pendant to monitor the program or check for errors, pressing a key lights up the screen but it is frozen and no buttons are responsive. A power cycle will allow it to run again for some time again before freezing.
    I have tried searching these forums and it seems every post with non responsive pendant has gone unanswered.
    I contacted Fanuc and they told me to look at the mainboard lights. Are those applicable past startup?
  • MOM January 31, 2025 at 5:43 PM
    Approved the thread.
  • byrol
    13
    5
    347
    • February 4, 2025 at 2:39 PM
    A robot is probably being used in the automatic working position. If the pendant robot freezes while doing automatic work, there may be many reasons for this.
    -The executed program may be too long or there may be too many subprograms or cycles in the program. The buddha will pile up after a while and the controller may freeze.
    -The main program running on your motherboard The motherboard may freeze after a while due to rom or ram problems. That's why Fanuc told you to compare the lights of the motherboard when the robot is working normally and the controller is frozen.
    -Another reason is a voltage leakage caused by your power line or a similar problem that affects your robot and the control may freeze. In particular, I have seen that the voltage fluctuation makes the controller inoperable and causes problems, and even the software becomes inoperable.
    -Testing it by making an exchange with a working version of the pendant and cable may also give you an idea.
    -After turning on the robot, waiting for hours without running any programs to see if the controller freezes will also give you an idea.
  • colarosa1
    • February 5, 2025 at 10:56 PM
    byrol thanks for responding.
    We have made no changes to the program or hardware and this cell has been running since 2016 so I dont believe it is an issue with the program
    I unfortunately do not have any spare parts or know good parts to use as a test.
    So far with the robot not running but the controller powered on I have not witnessed the pendant freeze up, but as I mentioned in the regular post it varies in the amount of time before there is an issue even when running.
Similar Threads
  • TP Freezing in Auto
    • nlodl
    • July 25, 2024 at 9:43 PM
    • Fanuc Robot Forum
  • AutoUpdate Process is frozen with message ''UD1: ¥plp¥M332896.COM Opening"
    • nhfMinion
    • August 3, 2022 at 1:55 PM
    • Fanuc Robot Forum
  • r30ib
  • ipendant
Users Viewing This Thread
  • 1 Guest
