Hi all. Have a problem I have solved but don't understand why my method didn't work. We have 2 robot cells - mirror images of eachother. I copied the jbi file over and tried to run it - pulse limits alarm went off. I then defined a new UF with the exact pulse data set up from robot 1 to robot 2, and called the program in the new user frame. The robot moved but to some very odd positions and some it couldn't reach at all. Why does redefining the exact user frame and copying the jbi file not work?
I have since followed the procedure of changing from relative - standard job and transferring this over so no long have the issue. Just curiosity in how the file / position data works if it's defined in the exact same user frame. Thanks in advance
