Palletizing program Fanuc
  • RonWonson
  • January 31, 2025 at 5:04 AM
  • RonWonson
    Hey I'm going to be programming an r2000 and using it for palletizing. The End Effector isn't even made yet but I need to get a jump ahead on the programming regardless and I need a place to start. The application will be simple but I've only had small experience with an LR mate.
    I basically have to implement this program for several other pallets and rows with each corresponding with each other. Like row 1 =pallet 1. Just because we run different product. Anyways I'm a little rugged and only have taught coordinates before then ran the a single program instead of using math to coordinate positions. If anyone would want to give pointers like I'd believe I need [r] [pr] and For Loops. Problem is I think my software is too old for For loops so an alternative would be nice too! Thanks for your time
  • Fubini January 31, 2025 at 5:37 AM
    Approved the thread.
  • KiloCo3026
    10
    • February 5, 2025 at 5:04 PM
    I'm assuming that you are not using PalletTool and are just using basic HandlingTool.
    You could teach User Frames for each of your pallet locations and Position Registers for each place position on the first layer. Each pallet should have a count Register for the current unit on layer and current layer(starting at 0 for the first layer). Each layer would have an offset applied to it based off the height of the units multiplied by the current layer count. You could do this a handful of ways with an offset condition, an offset PR applied to each point, or a buffer PR that you add the offset directly to and overwrite each time.
    If you have different layer patterns you may need to make another set of PRs for place positions and select those PRs based on the layer count. You would still teach those positions on the first layer though.
  • saberlars
    Robot, beyond Human..
    22
    232
    • February 7, 2025 at 6:32 AM
    1. Calculate Row_X, Column_Y, Layer_Z by Register value
    2. Define Depth_X, Width_Y, Height_Z
    3. Assign PR[10,1] = Row_X * Depth_X
    4. Assign PR[10,2] = Column_Y * Width_Y
    5. Assignl PR[10,3] = Layer_Z * Height_Z
    5. Add parameter with Offset or Tool_Offset wity PR[10]
      16:  ! RCL Calculate
      17:  R[91:Row_X]=(((R[11:CV1_Block]-1) MOD 9) DIV 3)
      18:  R[92:Col_Y]=(((R[11:CV1_Block]-1) MOD 3))
      19:  R[93:Lay_Z]=(((R[11:CV1_Block]-1) DIV 9))
      20:
      21:  ! Work to Work Distance
      22:  R[94:Width_X]=410
      23:  R[95:Depth_Y]=470
      24:  R[96:Height_Z]=(-420)
      25:
      26:  ! Distance * RCL
      27:  R[97:Offs_X]=R[91:Row_X]*R[94:Width_X]
      28:  R[98:Offs_Y]=R[92:Col_Y]*R[95:Depth_Y]
      29:  R[99:Offs_Z]=R[93:Lay_Z]*R[96:Height_Z]
      38:  ! Work Position
      39:  PR[91,1:Offs_1]=R[97:Offs_X]
      40:  PR[91,2:Offs_1]=R[98:Offs_Y]
      41:  PR[91,3:Offs_1]=R[99:Offs_Z]
      42:  PR[91,4:Offs_1]=0
      43:  PR[91,5:Offs_1]=0
      44:  PR[91,6:Offs_1]=0
      J PR[1:Block] 50% FINE Tool_Offset,PR[91:Offs_1] ACC70
    Or
    PALLETIZING-EX function. (If software installed)
    ABB, FANUC, Hyundai, Kawasaki
    Edited once, last by saberlars (February 7, 2025 at 6:38 AM).
  • RobcadSim
    63
    • February 10, 2025 at 7:40 AM
    For palletizing ,first you must make sure that how many stack types you have. Sometimes the stack shape is complicated(even if you use the PalletTool ), you have to write a code by yourself.
    But if your cost is enough,you can use iRVision for palletizing ,most of situation can be solved.
    Nice day~!
Similar Threads
  • How to Program - Machine Tending Demo
    • kbeau116
    • September 27, 2024 at 7:16 PM
    • Fanuc Robot Forum
  • Keep getting singularity
    • Abodame99
    • March 27, 2023 at 9:08 PM
    • Fanuc Robot Forum
  • Help with PLC querie for palletizing registers
    • MONIQUEZE
    • January 30, 2024 at 2:48 AM
    • Fanuc Robot Forum
  • Can it replace RobotStudio
    • ceilingwalker
    • August 22, 2023 at 2:36 PM
    • RoboDK
  • Fanuc Robot does NOT have "Program Select" option under the "Setup" menu...
    • MattJaeck
    • February 20, 2023 at 6:03 PM
    • Fanuc Robot Forum
  • Palletising program
    • Mangesh Shenavi
    • February 2, 2023 at 5:57 AM
    • KUKA Robot Forum
  • Represent a PR in a different User Frame
    • KPS93
    • December 11, 2021 at 10:07 PM
    • Fanuc Robot Forum
  • Pallet Program Fanuc using PR
    • vipinpunneri
    • August 18, 2021 at 8:37 PM
    • Fanuc Robot Forum
  • FANUC ROBOTS - Palletizing Function using User Frames?
    • Gabriel Cinti
    • July 19, 2021 at 8:05 PM
    • Fanuc Robot Forum
  • Using PR's and Registers to create a Palletizing sequence
    • VC3PRO
    • March 23, 2021 at 4:56 PM
    • Fanuc Robot Forum
