Hello all,
I am working on yaskawa robot NX100 - welding operations.
Often is happening that, when i start job, the controller show me alarm 9001. Start conditions and other welding setting is not relevant, because i have macro for calling job based on adjusted jobs from fronius, if i make weld with job:4 i see on welding machine adjusted job:4. So macro does work correct i think.
welding procedure is TIG without wire.
Today i made one weld, and after this mistake is showing again and again. When is this alarm i see on fronius that is disconnected from communication with the robot -> in this case is showing alarm 4110, therefore i havet turn off and turn on weld machine.
What i can do for remove mistake 9001?
Thank you
