Can't build any LS file with a joint move, error code 0x160002
  • Tarnarmour
  • January 22, 2025 at 9:14 PM
  • Tarnarmour
    26
    I've been automatically generating and compiling LS files into TP code for a while now with no issues, but I've just found a weird problem with timed joints moves. For context, I'm running the old 5.30 controller software version (compatibility for a customer with an old robot). Here's the LS file I'm trying to translate:
    /PROG  COL_PLC1
    /ATTR
    PROTECT		= READ_WRITE;
    TCD:  STACK_SIZE	= 0,
          TASK_PRIORITY	= 50,
          TIME_SLICE	= 0,
          BUSY_LAMP_OFF	= 0,
          ABORT_REQUEST	= 0,
          PAUSE_REQUEST	= 0;
    DEFAULT_GROUP	= 1,*,*,*,*;
    CONTROL_CODE	= 00000000 00000000;
    /MN
    	1:	J PR[1] 750msec CNT100 ACC100;
    /POS
    /END
    and here's the error I get when building:
    Quote
    Translating E:\plc_test\col_plc1.ls
    Error occurred during load
    E:\plc_test\col_plc1.ls(13)
    on line 13, column 38
    Undefined instruction
    on line 13, column 31
    Build Failed: Error translating program: Code: 0x160002: [SPRUNCMDF] status = 38000F; "ERSRCH 0X160002 " :
    If I change to a linear move, this works fine. If I change the velocity type to percentage, like 1: J PR[1] 100% CNT100 ACC100;, it's fine. What's really weird is that if I open the teach pendant and change the program, I can make it a timed move, and I can even print out an LS file. But that same LS file then will not re-build.
    Again this is with the old 5.30 software version, but does anyone have any idea about this?
  • HawkME
    570
    3,270
    • January 22, 2025 at 11:46 PM
    Probably a bug in the complier that Fanuc overlooked.
  • Hazard
    15
    55
    • January 23, 2025 at 7:06 PM
    Could be the unit of measure for speed. On my 5.30 robots I don't see msec as an available option. I only see mm/sec, cm/sec, inch/min, deg/sec, and sec.
  • Hazard
    15
    55
    • January 23, 2025 at 7:19 PM
    Actually those units of measure are for linear motions. For joint motions I only see % and sec.
  • Tarnarmour
    26
    • January 23, 2025 at 7:47 PM
    Quote
    So you can't even set the <msec> option? I can set it in the teach pendant, I just can't build an LS file that has it set. Very weird, but good to know that <sec> will probably work.
  • Build codes
  • Compiling eror
Users Viewing This Thread
  • 4 Guests
