I'm working on a palletizer fanuc robot, and production want to change the pattern in one of the unit loads. I have already edited the old unit load in PalletPRO and saved the file on a USB stick as a .VR file. My question is, How do I upload this file to my fanuc robot to overwrite the old unit load
How to upload a .VR file to a fanuc robot, i want to overwrite an old unit load
drekel91 -
January 17, 2025 at 5:32 AM -
95devils
January 17, 2025 at 11:48 AM Approved the thread. -
- Plug your USB stick into either the USB port on the controller (UD1) or the one on the pendant (UT1).
- Menu>File>File, and navigate to the directory of the USB media you just inserted.
- Menu>Setup>Unit Load, then press NEXT, then press F2 <LOAD>.
- The message that pops up will confirm the active directory, in this case either UD1 or UT1 depending on your choices in steps 1 and 2. Press F2 <DONE>.
- Navigate to the file in question and press F2 <LOAD>.
- Follow additional prompts as needed.
Hope this helps.
