  4. ABB Robot Forum
wrong resolver offset value
  • Enio
  • January 14, 2025 at 1:26 PM
  • Enio
    183
    hello guys, We have a welder with IRC5 controller equipped with IRBP type D positioner .
    Can someone help us to see the WobjSTN1 workobject values refer to wobj0?
  • robiman
    10
    115
    • January 14, 2025 at 2:42 PM
    i'am not sure what you mwean
    Wobj Data you can find here
    PERS wobjdata WobjSTN1 :=[ xxxxxxxxxxx
    resolver offset value.... (maybe you mean Calibration offset)..... you find in the moc.cfg file
    MOTOR_CALIB:
    -name "pos1_1" -valid_com_offset -cal_offset 2.8183 -valid_cal_offset \
    -latest_calibration_method 1
    http://www.hw-automation.de<br />Teach Pendant Repair S4- IRC5
  • Enio
    183
    • January 14, 2025 at 3:03 PM
    hello robiman, when we look to this PERS wobjSTN1 we do not see translation values from wobj0,
    in s4c we are abble to see actually the values in mm where the positioner plate is refer to wbj0
  • Lemster68
    295
    2,458
    Blog Articles
    7
    • January 14, 2025 at 3:09 PM
    It might not be taught yet.
  • Enio
    183
    • January 14, 2025 at 3:36 PM
    lemster ,actually is working,but in declaration i can not see the actual values in mm of the plate refer to the base frame
    PERS wobjdata wobjSTN1 := [FALSE,FALSE,"STN1",[[0,0,0],[1,0,0,0]],[[0,0,0],[1,0,0,0]]];
    PERS wobjdata wobjSTN2 := [FALSE,FALSE,"STN2",[[0,0,0],[1,0,0,0]],[[0,0,0],[1,0,0,0]]];
  • Lemster68
    295
    2,458
    Blog Articles
    7
    • January 14, 2025 at 4:11 PM
    It will still work even if it has not been taught.
  • robiman
    10
    115
    • January 14, 2025 at 4:16 PM
    you can test it when you move in Workobject mode:
    move the robot to the Mounting Plate on STN1 and rotate it
    the robot must be in workobject mode
  • Enio
    183
    • January 14, 2025 at 4:53 PM
    lemster i am not sure what you mean, so the STN1 is define in Calibration menu under Reference system still Object frame and User frame values are 0.
  • Lemster68
    295
    2,458
    Blog Articles
    7
    • January 14, 2025 at 4:59 PM
    Have you searched here for the manual which will tell you the proper calibration of that positioner?
    Manuals, Software and Tools for ABB Robots
  • Skooter
    167
    2,005
    • January 15, 2025 at 12:56 AM
    Check data all the modules, perhaps it was in a different module when the wobj was defined.
    I seem to remember that happening to me a long time ago.
  • Enio
    183
    • January 15, 2025 at 8:44 AM
    • #11
    yes robiman , in workobject mode the robot turns with the table sincronized so it has been taught ok
  • robiman
    10
    115
    • January 15, 2025 at 9:25 AM
    • #12
    you are realy sure you have only one WobjSTN1?
  • robiman
    10
    115
    • January 15, 2025 at 11:10 AM
    • #13
    you can find the data in the moc.cfg file
    SINGLE:
    -name "STN1" -use_single_type "STN1" -use_joint "PLATE1"\
    -base_frame_pos_x 1.36493 -base_frame_pos_y 0.993543\
    -base_frame_pos_z 0.218675 -base_frame_orient_u0 0.499241\
    -base_frame_orient_u1 0.499043 -base_frame_orient_u2 -0.500491\
    -base_frame_orient_u3 0.501222 -use_single_jog "STN1"
  • Enio
    183
    • January 15, 2025 at 11:29 AM
    • #14
    Thanks robiman
Similar Threads
  • wrong resolver offset value
    • Enio
    • October 3, 2024 at 1:16 PM
    • ABB Robot Forum
