Help with SET instruction
  • darth0
  • January 14, 2025 at 7:33 AM
  • darth0
    138
    Hello!
    Im having some troubles using the SET instruction on YRC1000.
    I want to perform an Absolute shift with the SHFTON instruction, my program is written like this
    SET P000 " Here i would like to set P000 (0,200,0,0,0,0) for the SHFTON to shift 200mm in Y direction--> How do i set these values on the controler ? Does P000 have to be set up as an array P[]?
    MOVJ VJ=100.00
    MOVL V=80.0
    MOVL V=80.0
    MOVL V=80.0
    MOVL V=80.0
    MOVJ VJ=100.00
    SHFTON P000
    MOVJ VJ=100.00
    MOVL V=80.0
    MOVL V=80.0
    MOVL V=80.0
    MOVL V=80.0
    SHFTOF
    END
    Thank you for all help !
  • Go to Best Answer
  • darth0
    138
    • January 14, 2025 at 7:40 AM
    Should i be using SETE instruction?
    is it that simple :upside_down_face:
  • Burty
    • January 14, 2025 at 8:09 AM
    • Best Answer
    Yes, it is that simple
  • darth0 January 14, 2025 at 8:09 AM
    Selected a post as the best answer.
  • BMGN01
    • January 14, 2025 at 11:25 AM
    Use the SETE function and set (1), (3), (4), (5) and (6) all to 0, with (2) set to 200.
    I have noticed the units are sometimes different and sometimes not, so 200 may need to be 20,000 instead of 200 but start small at first! :grinning_face_with_smiling_eyes:
  • 95devils
    231
    8
    1,938
    • January 14, 2025 at 12:05 PM
    Quote from BMGN01
    On the YRC the X,Y, and Z are in millimeters. The Rx, Ry, and Rz are in degrees. Looking at ROBOT, CURRENT POSITION, the XYZ goes out 3 decimal places, rotation 4 decimal places.
    20000 set into X,Y, or Z is 20 mm.
    20000 set in Rx,Ry, or Rz is 2 degrees.
    If the position variable is formatted as pulse then the number is a whole number.
  • darth0
    138
    • January 14, 2025 at 12:56 PM
    Quote from 95devils
    How does one change the Format of a position variable from pulse to xyz?
    Is it based on what format is displayed on axis positions ( pulse / XYZ) or ?
  • 95devils
    231
    8
    1,938
    • January 14, 2025 at 1:29 PM
    The CNVRT instruction under ARITH will convert a position variable from pulse to XYZ or a XYZ to another XYZ.
    Example: Pulse to Base, Robot, or User.
    Example: Base to Robot, or Robot to User.
Similar Threads
  • Programming of an online path correction
    • CFL_Max
    • January 8, 2025 at 4:27 PM
    • Yaskawa Motoman Robot Forum
  • Question Regarding Yaskawa DX200: How to Update Z-Height on a User Frame?
    • Stig Lindberg
    • November 8, 2024 at 3:42 PM
  • ABB separate routine (macro)
    • Jleon89
    • July 30, 2024 at 7:04 PM
    • ABB Robot Forum
  • Fixted Tool Load Definition in Block Programming
    • dohlfhauldhagen
    • June 3, 2024 at 7:36 PM
    • Kawasaki Robot Forum
  • KRC4 - Custom Weld Timer
    • notverycreeative
    • December 5, 2021 at 1:33 AM
    • KUKA Robot Forum
  • Material Handling
    • Fabian_Munoz1
    • April 21, 2024 at 11:38 PM
    • ABB Robot Forum
  • Syntax Error in instruction data(J:NEUINST L:****) [0]
    • MST-314
    • January 31, 2023 at 1:03 PM
  • Comarc Issues not working?
    • Loki
    • January 8, 2021 at 10:02 AM
  • Alarms to PLC
    • white_raven
    • September 13, 2021 at 10:03 PM
  • KUKA PALLETIZING CODE
    • Jeff_Rob
    • May 12, 2021 at 4:02 PM
    • KUKA Robot Forum
  • SET
