"error 0380: Position not checked", can not confirm position from Data on Main menu
  • Prokita
  • January 11, 2025 at 3:23 AM
  • Prokita
    Hi everyone!
    Currently I have an "error 0380: Position not checked". I followed the steps exactly as in the documentation with in tech mode and management security with second home, moving FWD back to zero, but when I chose DATA on Main menu, the "Confirm Position" button does not appear, so I can not check position.
    I am using DX200 controller. Please help me this issue, thank you so much everyone.
  • Fubini January 11, 2025 at 5:58 AM
    Approved the thread.
  • Robodoc
    56
    7
    1,058
    • January 11, 2025 at 2:24 PM
    do you have an external axis?
    Robodoc
  • 95devils
    230
    8
    1,934
    • January 11, 2025 at 4:37 PM
    Like robodoc said. Do you have multiple pieces of hardware on the controller? Multiple robots or external axes or base track.
    If the page key is showing use it to go to each piece of hardware. Take each piece of hardware to the second home position. Then confirm the position.
  • Haze
    14
    • January 11, 2025 at 6:21 PM
    Check in the bottom line, where the error is showed, which of the Robots/Axes Groups is highlighted.
    You only get the "Confirm Position" button on the pages of the Axis Groups which require confirmation.
  • Prokita
    • January 11, 2025 at 6:28 PM
    Quote from Robodoc
    HI Sir Rpbodo,
    I have an extenal axis, it located on robot'gripper Sir
    Edited 2 times, last by Prokita (January 12, 2025 at 11:22 AM).
  • Robodoc
    56
    7
    1,058
    • January 12, 2025 at 2:19 PM
    Go to the second home page and press the page down key to get to the external axis and then press the data button.
    Robodoc
  • Prokita
    • January 12, 2025 at 4:24 PM
    Yes Sir, it worked now. Thank you so much to Robodoc, Haiz, 95devils for your help.
  • home position
  • second home position
  • error 0380
