PMS 18
  • anafm001
  • January 10, 2025 at 11:53 AM
  • anafm001
    5
    Hi!
    I have a KUKA KR 210 R2700 and KRC4 cabinet, with the following message: PMS18: accumulator defective - charging test failed. This message comes out when the robot picks up the tools that are in the upper part of the warehouse (2.5 meters approximately), do you know what could be the cause and how to solve it? And this warning refers to the batteries or to the hydraulic accumulator? Thank you very much.
    panic mode
    1,267
    13,037
    • January 10, 2025 at 2:12 PM
    message refers to pair of 12V SLA batteries, not counterbalance. there is no sensor on the counterbalance.
    SkyeFire
    1,042
    9,388
    • January 10, 2025 at 5:29 PM
    I'm not sure why the error would only occur when specific tool changes are being performed, however. That's odd. If the batteries are confirmed to be good, and this error is persistent and consistent, I would check what kind of electrical interactions those tools have with the KRC's internal power circuit. A tool should not be able to brown-out the battery charging circuit unless some bad wiring has been done.
    panic mode
    1,267
    13,037
    • January 10, 2025 at 7:49 PM
    as i recall batteries are tested very infrequently and i would guess that observed is simply a coincidence. coincidences become a pattern only when they happen several times in that same situation.
    SkyeFire
    1,042
    9,388
    • January 10, 2025 at 8:44 PM
    Quote from panic mode
    I'm honestly not certain I've ever seen this error before. The "Accumulator voltage low on shutdown" one, yes, but that one is obviously just checking the batteries during controlled powerdown. I wasn't even sure if the KRC checked the batteries during operation.
  • anafm001
    5
    • January 14, 2025 at 10:05 AM
    Quote from SkyeFire
    Ok, I will check the batteries!.The robot only pick up the tool, it does not perform operations with it. The warning appears when picking up the tools that are at the top of the warehouse.
Similar Threads
  • Collision detect
    • Sweetwill5800
    • October 21, 2023 at 2:13 PM
    • Fanuc Robot Forum
  • How to "BGL wants program to JMP LBL"?
    • HalbesYoyo
    • March 27, 2024 at 3:40 PM
    • Fanuc Robot Forum
  • KUKA errors messages manuals
    • bigboss
    • November 12, 2014 at 11:07 AM
    • KUKA Robot Forum
  • Replacing 710iC arm
    • PPP
    • September 20, 2022 at 12:15 AM
    • Fanuc Robot Forum
  • BGLOGIC code that I have found useful
    • flatcurve
    • December 16, 2010 at 9:35 PM
    • Manuals, Software and Tools for Fanuc Robots (you should look here first before posting)
  • Fanuc Spot Welding Manual Weld
    • RedtheRobotTech
    • September 8, 2021 at 3:29 AM
    • Fanuc Robot Forum
  • Oil change of M16İ robot
    • byrol
    • January 26, 2021 at 7:09 PM
    • Fanuc Robot Forum
