Help with understanding how points are defined in .ls files
  • TTalma
  • January 9, 2025 at 7:46 PM
  • TTalma
    I am new to the FANUC system and am learning how to program .ls files. My ultimate goal is to have a C# application generate a file and load it into the controller and start the program. I found some sample code online and put together a program (Below).
    The issue I am having is I do not understand how the coordinates work when in the .LS file. For example I have point 1 defined as:
    P[1:"Point1"]{
    GP1:
        UF : 2, UT : 1, CONFIG : 'N U T, 0, 0, 0',
        X = 1000.000 mm,  Y =    0.000 mm,  Z =    0.000 mm,
        W =  -90.000 deg, P =   90.000 deg, R =    0.000 deg
    At the home position the tool is in the correct orientation, Pointing in the -Z direction. When running my application it moves to this point, once reaching it the tool is pointing in the positive Y direction.
    I want the tool pointing in the -Z direction at all times , so I changed point 1 to look like:
    P[1:"Point1"]{
    GP1:
        UF : 2, UT : 1, CONFIG : 'N D B, 0, 0, 0',
        W =    0.000 deg, P =    0.000 deg, R =    0.000 deg
    This causes a fault when I try to run it, with the messages stating "Position not reachable"
    I used the virtual pendant to set a PR point, It's value (when viewing the data on the virtual pendant) is:
    PR[1:"Home"]{
    GP1:
        UF : F, UT : F, CONFIG : 'N D B, 0, 0, 0',
        X =  500.000 mm,  Y =  250.000 mm,  Z =   50.000 mm,
    And the system has no problem with that point.
    The points I put are within range of the machine so I don't understand what I am doing incorrectly. Could someone point me to a good definition of how to set the CONFIG value and the W,P,R values, as well as how they relate to each other in order to keep the tool pointing in -Z at each point?:question_mark::question_mark:
    My complete (Working, with Tool pointed in positive Y when not at home position ) program is here:
    /PROG MOVE_TO_POINT
    /ATTR
    OWNER = MNEDITOR;
    COMMENT = "Moves to position";
    PROG_SIZE = 7326;
    CREATE = DATE 17-11-17 TIME 07:43:46;
    MODIFIED = DATE 17-11-17 TIME 07:43:46;
    FILE_NAME = ;
    VERSION = 0;
    LINE_COUNT = 267;
    MEMORY_SIZE = 8102;
    PROTECT = READ_WRITE;
    TCD: STACK_SIZE = 0,
    TASK_PRIORITY = 50,
    TIME_SLICE = 0,
    BUSY_LAMP_OFF = 0,
    ABORT_REQUEST = 0,
    PAUSE_REQUEST = 0;
    DEFAULT_GROUP = 1,*,*,*,*;
    CONTROL_CODE = 00000000 00000000;
    /APPL
    /MN
    : ! Robot: XX ;
    : UTOOL_NUM=1 ;
    : UFRAME_NUM=2 ;
    :J P[1] 25% FINE ;
    :J P[2] 50% FINE ;
    :L P[3] 100mm/sec FINE ;
    :J PR[1:Home] 25% FINE ;
    /POS
    P[1:"Point1"]{
    GP1:
    P[2:"Point2"]{
    GP1:
    X = 1000.000 mm, Y = 1000.000 mm, Z = 0.000 mm,
    P[3:"Point3"]{
    GP1:
    X = 1000.000 mm, Y = 1000.000 mm, Z = 1000.000 mm,
    /END
  • Nation
    Typical Robot Error
    547
    1,925
    • January 9, 2025 at 8:13 PM
    What are your values for UTOOL 1, and UFRAME 2? What arm are you using?
    The robot will attempt to move the TCP to the point defined in your UFRAME. Fanuc uses euler angles, defined from the currently active frame. We go over how they work in this thread.
    Since there are typically multiple solutions to a point, config narrows them down. I made a short video on them years ago:
  • TTalma
    • January 9, 2025 at 9:41 PM
    Quote
    I am unable to find the values for UTOOL and UFRAME. I am not sure what they are other than reading their definition.
    I am new to programing robot in general. The tool I am using is a pointer set to 180mm in the Z direction. all other values were set to 0.
    When setting up the project I used all defaults.
    The robot in my project is a M-710.
    Maybe images will help. Here is a picture of the robot in the home position, with the pointer in the correct orientation:
    Here is a picture of the tool pointing in the positive Y (incorrect orientation)
  • HawkME
    568
    3,268
    • January 10, 2025 at 3:57 AM
    You changed your config from NUT to NDB. So I'm guessing your telling the robot to do a back flip.
  • coordinate system
  • Tool base
