I was playing around with KROSET when I added the enviroment the robot is supposed to work in. I right clicked on the "project -> add -> environment -> obstacle" and importet it as a STL file I recived. The issue is that the object will randomly dispear. If I move the camera it can randomly disapear. If I play around with the transparency it most likely will disapear. Anyone who knows what exactly is happening and also if possible how to get the object visible again? I have attached a video showing the issue.
KROSET environment obstacle disappears
Robotto -
January 9, 2025 at 1:15 PM -
I have never seen this before and also I use the latest version of KRoset, but I would be looking in 2 areas:
- Model size and complexity (consider having separate stl's).
- Viewer settings.Looks like a strange model to me (YF mounting, conveyor and encapsulation).
I would be tempted to split those models into 3 separate stl's.
- YF Mount.
- Conveyor.
- Encapsulation.
I would then expect better transparency control over each object.
