Programming of an online path correction
  • CFL_Max
  • January 8, 2025 at 4:27 PM
  • CFL_Max
    5
    Hello everybody:hi-bye:,
    I need some help please. I am a complete beginner in programming robots. I have only written a few simple static programs so far. I am working on a Yaskawa HC20DTP with a YRC1000m with Smart Pendant.
    I would like to move my Yaskawa from a pose A to B.
    However, the pose must always be corrected in the z-direction (tool coordinates).
    The correction is made via digital signals. For example, if input 4 == 1, the tool should be corrected in the z-direction (tool coordinates) in the positive direction and if input 5 == 1 in the negative direction.
    However, I cannot find a approach on how to program this. I have read about the ACORON function, but I have not found this function in YRC1000m.
    Perhaps an alternative would be to use MotoPlus SDK.
    Can you help me here?:help:
    :vulcan_salute_light_skin_tone: CFL_Max
  • Go to Best Answer
  • MOM January 8, 2025 at 4:45 PM
    Approved the thread.
  • arigatomrroboto
    • January 8, 2025 at 8:21 PM
    You could use if/then statements and jump/labels for the various cases along with position variables for various +/- positions. Or you could set up a position variable and modify the Z component based on the different cases. Yaskawa provides free manuals on their website that dive deep and would be a great resource if you're just starting out.
    Images
      • 3.39 kB
      • 190 × 200
      • 4
  • CFL_Max
    5
    • January 9, 2025 at 9:32 AM
    first, thank you very much for the quick reply.
    I am working with the operating instructions “YRC1000micro: INFORM Language Instructions”. However, the description of the commands is not very understandable for me.
    I still have a question about the line “MOVJ VJ=50”. It is clear to me that the robot moves linearly in joint coordinates, but not to which pose. The target pose was not specified.
    But the way I saw it in the manual, the code means it moves to a pose1 that was defined somewhere. Then the if/then statement is processed, right?
  • darth0
    154
    • January 9, 2025 at 11:05 AM
    Quote from CFL_Max
    MOVJ is Joint move instruction, it isnt interpolated ( robot will not move in a straight line).
    MOVL is a Linear move instruction, it IS interpolated ( robot will move in a straight line).
    The position is written in the move instruction itself, when you register the MOV instruction, the current TCP position is "written" into the MOV instruction itself.
  • CFL_Max
    5
    • January 9, 2025 at 11:31 AM
    Quote from darth0
    I apologize for expressing it incorrectly. I know that with MOVJ the robot doesn't move linearly in cartesian coordinates, but it does move linearly in joint coordinates.
    Okay, thanks. So the data is saved as a local pose (in the C00000 and C00001) in the program.
    I have now written a program and exported it as a JBI file:
    /JOB
    //NAME Sample1
    //POS
    ///NPOS 2,0,0,1,0,0
    ///TOOL 1
    ///POSTYPE PULSE
    ///PULSE
    C00000=48858,-19574,-75040,2307,-147086,-38869
    C00001=132031,17004,-48612,8204,-148602,-91982
    ///POSTYPE TOOL
    ///RECTAN
    ///RCONF 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
    P00002=0.000,0.000,10.000,0.0000,0.0000,0.0000
    //INST
    ///DATE 2025/01/09 12:15
    ///ATTR SC,RW
    ///GROUP1 RB1
    NOP
    MOVJ C00000 VJ=5.00
    MOVL C00001 V=100.0
    IFTHENEXP B000=1
    JUMP *up
    ENDIF
    *up
    IMOV P002 V=50.0
    END
    In this code, however, first the robot moves to pose C00000, than to pose C00001 and then it checks the if statement. However, the if statement should be checked during the linear movement.
    It seems that I haven't quite understood it yet.:loudly_crying_face:
  • darth0
    154
    • January 9, 2025 at 12:23 PM
    Hey!
    Do you maybe have the basic understanding of C/C++ programming, otherwise i suggest you read the inform Language PDF to learn the basics of how the language works.
    The IF logical instruction can be described as a loop for example:
    IF B000 < 3 then
    MOVL V=50
    MOVL V=50
    MOVL V=50...
    END IF
    Only the parts between lines are being looped.
    Secondly, nothing is changing the value of B000 ( you need to set the variable B000 with something like a counter, otherwise it will never get to 1 and it will never go into the IF loop.
    I would write something like this based on your problem, but you need to explain a bit more in detail what you are trying to achieve and with what. You are trying to shift TCP position in Z direction based on what ? What are the C000 and C001 Positions representing, the Shift value or absolute position the TCP needs to reach depending on Inputs #4 and #5 ?
    I would implement a SFTON instruction then.
    NOP
    SET P002 " Set P002 for your Z+ shift position
    SET P003 " Set P003 for your Z- shift position
    IF IN#(4)==ON
    SFTON P002
    Write your move instructions here
    SFTOFF
    END IF
    IF IN#(5) == ON
    SFTON P003
    SFTOF
    END IF
    END
    The SFTON instruction can be used to shift the coordinate system or position. You need to Set P002 ( 0,0, + Z-value,0,0,0)
    P003 (0,0, - Z-value, 0, 0, 0)
    Hope this helps but you really need to read the INFORM PDF and learn the language and syntaxes.
    Edited 2 times, last by darth0 (January 9, 2025 at 1:48 PM).
  • CFL_Max
    5
    • January 9, 2025 at 4:09 PM
    Thank you!
    Yes, I have some experience in programming (C++, C# and Python).
    But in all languages the “If-Operator” does not work like a loop. Do you mean that it becomes a loop because of the continuous repetition of the Yaskawa program?
    As soon as the condition of the if operator is true, the statement would be executed. So all MOVx commands in the statement would be processed in sequence.
    But that is not what the program is supposed to do.
    Fair point. Perhaps I have described my problem too imprecisely. Here is a better description:
    I want to sand a workpiece with a random orbital sander.
    I have the random orbital sander and the corresponding force and torque sensor from OnRobot.
    The only problem is that I can't get the analog values of the force and torque sensor because OnRobot has a Compute Box on which I program the logic. The box is connected to the sensor and the random orbital sander. The Compute Box is connected to the YRC1000micro via digital I/Os.
    I have programmed the logic of the Compute Box so that I achieve a contact pressure of 20 N. If the contact pressure is too high, I switch DigOut5 to True and DigOut6 to False. If it gets too low, I switch DigOut5 to False and DigOut6 to True.
    The DigOuts of the Compute Box are connected to DigIn5 and DigIn6 of the robot.
    If Input5 is True, more pressure is applied in the z-direction in tool coordinates and if Input6 is True, exactly the opposite.
  • darth0
    154
    • January 10, 2025 at 7:08 AM
    Quote from CFL_Max
    Thank you!
    AFAIK all robots read the program in "Cascade/ladder" type, so first it reads line1, executes it, goes to line 2 etc.... untill it reaches END.
    That is why your program first executed the normal moves and probably didnt even go into the IF "loop" since you didnt have B000 "SET" or anything that would increase the value of B000 to 1 for it to go into the IF loop.
    For your program i would use the "logic" something along theese lines:
    DigOut5 should trigger one IF loop where you would use the SHFTON command to shift your coordinate system in the +Z direction .
    DigOut6 should trigger the second IF loop where you would also use the SHFTON command and shift your coordinate system in the -Z direction.
  • darth0
    154
    • January 10, 2025 at 8:07 AM
    Gonna add a subquestion:
    If i understand you correctly, the angle grinder should shift in Z direction depending on the Force it senses ( F>20N --> +Z corection, F<20N--> -Zcorrection)?
    This is basically a regulation of position through Force meassurments.
  • TSGIR
    81
    714
    • January 10, 2025 at 9:51 AM
    • Best Answer
    Hi
    You couldn't do correct path when robot is moving with normal jobs, only you can use Motoplus for it.
    You need to know about correction path function in Motoplus and write some code for it. The Motoplus file is always running in back of robot and everytime you press a key, can you tell robot how much go up or down.
    Normal method couldn't help you, for example you are moving from A to B , you couldn't correct Z direction between these two points by any code in jobs. Only you can use a method same as laser tracking by Motoplus.
  • darth0
    154
    • January 10, 2025 at 10:14 AM
    • #11
    Quote from TSGIR
    Hi
    TSGIR
    Hey, i thought this was the case and regulations cannot be done during moving.
    How is the Weld path being corrected/regulated with the use of a Seam tracker then?
    It corrects the path in real time, is that done with some Background logic program that is always runing in the background ?
    Im still learning the ins and outs of robotic programming, thank you for the reply
  • CFL_Max January 10, 2025 at 10:51 AM
    Selected a post as the best answer.
  • CFL_Max
    5
    • January 10, 2025 at 12:01 PM
    • #12
    Quote from TSGIR
    Hi
    @TSGIR
    thank you very much for your answer. I expected this.
    @darth0, @arigatomrroboto
    thank you very much for your help :smiling_face:
  • 95devils
    234
    8
    1,947
    • January 10, 2025 at 2:25 PM
    • #13
    Quote from darth0
    There is an additional board (ACP02) installed. There is also software written as a function for seam tracking.
  • TSGIR
    81
    714
    • January 10, 2025 at 4:03 PM
    • #14
    Quote from darth0
    TSGIR
    For use Motoplus, you need software and hardware dongle, after that you can write your codes, create a OUT file, load on the controller and use it to correct path.
    Also it need to active some functions on the robot controller.
    You can download Motoplus manuals, i think 4 manual you can find for it, each manual explain about software, functions and setting.
Similar Threads
  • Best practice: Parametric placement with automatic path generation -> Software ?
    • stagrob
    • January 6, 2025 at 8:47 AM
    • General Discussion of Industrial Robots Only
  • yrc1000 micro
  • HC20DTP
  • smart pendant
