Hello everyone, I need some help with my KRC4 controller. What I need is for the 24V outputs to be deactivated when pressing the emergency stop button, or for some connection on my X11 port that would either send or pull down a 24V signal. I've measured the pins on the X11 and all of them have a constant 24V, which I understand is for external safety signals. I would like to know if there is any pin that changes state with the internal safety of the robot. I hope this makes sense, and thanks in advance!
KRC4 Controller, X11, and Emergency Stop Assistence
LucassNieva -
January 7, 2025 at 8:39 PM -
KRC4 controller manual shows EStop status on X11 are two contacts, terminals 37-38, and 55-56
so you can run power to your outputs through those contacts. but... if anything goes wrong (overload or short circuit) you are going to damage the SIB board and that is going to be expensive...
so better idea is to only use those for signals and let the heavy lifting be done by something external and lower cost.
you can add safety monitoring relay to monitor X11 EStop status. then you can use contacts of that relay to control the power to your outputs. chances are your monitoring relay contacts have low current ratings, so you would likely need to add a pair of contactors and have them monitored as well (by the same monitoring relay).
Thank you for responding so quickly. That is my idea, to install a relay. The problem I have is that the signals from my X11 do not change state when pressing the emergency button. I’m not sure if this is due to a configuration issue.
you need to be precise.... how are you testing?
and what do you mean by "they do not change state" when pressing EStop? what is the state?
are you able to move the robot? if you can move the robot, EStop must be ok so those contacts must be closed.
Sorry, when I refer to changing state, I mean that these signals are 24V and when pressing the emergency button on the smartPAD, they do not drop to 0V; they always remain at 24V. I understand this, as they are signals for doors, external emergency buttons, etc. What I need is some signal from the robot that goes from 24V to 0V when pressing the emergency button on the smartPAD. I have a laser connected to the robot, so I need to stop it along with the robot. I hope this makes sense.
no problem. pretty sure that i do understand your objective and you do not understand replies.
be precise...
there is more than one KRC4 type and more than one X11 type. you did not confirm which one you have and what pins you are trying to use for this.
outputs from X11 are dry contacts (potential free contacts). there is no 24V or 0V on them - unless you bring voltage to those contacts.
If nothing is connected to X11 interface, you can measure such voltage on the safety input circuits. But that is wrong circuit... You want to use KRC safety output circuits.
you did not answer my questions. be precise...
how are you testing? are you able to move robot? if so what is the status at the safety outputs? do you know how to test relay contact? measuring voltage will be fruitless if this is not wired into a circuit. if not wired, one would have to test it with continuity tester or ohm meter.
what is the configured safety interface? if X11 is installed, most likely that is the safety interface - unless someone bypassed it and decided to use one of fieldbus based options (ProfiSafe, CIP safety or FSoE).
Sorry for not understanding! Let’s go step by step. My robot is working correctly, I have a SIB board with ports X253 and X252 in the Harting X11 connector, and I don’t have any external connections. The robot is in a cell, but for now, there are no safety systems or PLC. I have the pins of the X11 connector bridged to make it work. I understand these are dry contacts, but when the connector is plugged in, I get 0V, and when I unplug it, I get 24V. So, I interpret that the relays on the SIB board are powered with 24V internally. Now, I would like to use X252 to stop or send a logical signal when pressing the emergency button on the smartPAD. I am measuring with a voltmeter and also with a continuity tester. How do the Local E-STOP outputs of X252 work? I’m not fully understanding how they function. Could you explain it to me? Sorry for the ignorance and thanks for the help.
.. I understand these are dry contacts, but when the connector is plugged in, I get 0V, and when I unplug it, I get 24V. So, I interpret that the relays on the SIB board are powered with 24V internally...
On which contacts do you measure 24v?
Doubt that you get it on a contact 37 - 60 on x252. On those dry contacts you can't measure any voltage, until you connect it to a power supply by your selfmade connector.
Panic_modes schematic shows the contacts, there is not much to explain about them. They open and close when the corresponding comdition is triggered. For example contacts 37—38 are shortened when internal e-stop is OK.
Hello Hermann, thanks for responding! The 24V are on the X253 signals. I understand that 24V are sent out and return to test if, for example, the cell door is closed. Is that correct?
Yes, but for your question in first post this is completely irrelevant.
Those signals are used to connect external e-stop, fences, light curtains and so on.
When you want to stop your own equipment like the laser, you must use the dry contacts from X252.
Looks like you should hire someone who knows a bit more about electronics.
woah... why are you doing that????
i would recommend to stay away from any internal circuitry and specially naked boards (CCU, SIB, RDC...). same applies even for trained people who are familiar with ESD, and know the actual pinout of the connectors, how to interpret schematics etc. because one mistake or slip-up and you can have things damaged... or worse.
if you want help, you came to the right place but... to get correct advice, you need to follow instructions and answer asked questions. which you don't.. and it was asked several times already ("on what exact pins did you measure ..."). post #2 shows exactly where EStop status should be checked. but you did not... and it took some effort to extract from you that you are messing completely different circuit. because you do not know the difference between input and output?
inputs are signals that robot can sense. the EStop button is wired to one of internal inputs and not to X11.
outputs are signals that robot generates. and the EStop status is one of those generated signals. this signal is active (contact closed) when robot does not sense any EStops (this status combines several input signals, not just one from smartPad).
and as herman says, you are not qualified to do this. you need someone that knows much more. not just electronics but also understands safety circuits and robot safeguarding.
you did not even state what kind of laser you want to control. if this is a sensing laser (Class I for example) they are not dangerous but could be annoying or irritating if they are shining beam of light while moving. this mere annoyance can be dealt with easily, even without safety rated circuitry.
but if the laser is powerful enough and can cause harm to humans (damage eyesight or burn skin) like cutting or welding lasers, then linking them only to an EStop is unacceptable. in this case cell guarding must be used also monitored and part of safety interlock.
I think the translator caused some misinterpretation in certain points, but it’s true that I still lack training on the topic of robots and their safety systems. Anyway, I was able to solve it, thank you all very much, you’ve been a great help!!
do you mind sharing your solution?
Of course. And please let me know if you think anything is wrong. My laser is for cutting, and it has two 24V digital inputs: one for cutting, and the other is for the robot failure alarm, which shuts down all the laser systems. So, what I did was connect 24V to terminal 37, and output from terminal 38 to the relay coil. In the NO (Normally Open) contact, I have the laser power-on signal connected (if there is an emergency stop from the robot, I turn off the cutting). Finally, in the NC (Normally Closed) contact of my relay, I have 24V directly to the alarm signal. When the relay drops, this signal is activated, turning off the laser and signaling the failure. What do you think?
if the terminals 37 and 38 are pins on X11, that means you are using single channel of the EStop circuit to drive some relay. then relay contact is tied to some input on your laser. and another relay contact is driving sound alarm. this of course can work but without seeing entire installation i cannot say if i agree or not.
if the cell is properly guarded so robot cannot just turn around and start blinding people or cutting them in half, and one cannot access the robot area without shutting down the laser, this may be ok, at least functionally.
if that laser input is a safety input and the only protection - then answer is categorical no. first problem is that you are only using single channel. so you have no redundancy. but even if you turn your relay on through both X11 contacts (37-38 and also 55-56), your relay is also a single device (so by definition there is no redundancy). and also it is probably a general purpose relay, that is not safety rated. for a safety application that relay would need to be monitored by a safety controller which is not the case. and it would not qualify for more than what you have even if you:
a) put two of them with monitoring relay or
b) replace them by two safety relays but without monitoring relay.in general one should not mix standard and safety components or IO. one notable exception is using higher grade device (safety) for lower grade function (standard) if this is used only for annunciation or display but ... not as a safety interlock.
Panic_mode already has mentioned it, but I think not really complete. With a laser that can cut things like wood, steel, aluminum, meat... you need a laser resistant housing with safety switches at doors and also connect them to your laser enable signal. E-stop is not the only thing to use.
Just saying, it's your life and health.
Yes, I totally agree that the security measures I'm implementing are limited. This is a new project that's still being developed, and security will be improved over time. Currently, both the robot and the laser are contained within a closed cell, so if the robot starts spinning and firing in any direction, it would only damage the cell itself. I should also clarify that the relays are indeed safety-rated, but I could improve what I have by making it redundant. Thank you very much for your help!
Can I ask you a question? I installed a Beckhoff EK1100 on my robot and correctly mapped the inputs and outputs to the module, meaning it works fine. However, I'm not able to set all the outputs to 0 when I activate the E-Stop button. I read that this can be done from WorkVisual, but I'm having trouble with it. Could you help me with this?
.. I read that this can be done from WorkVisual, but I'm having trouble with it...
I also would have trouble to do this from WoV. You can't, except you write a routine, using WoV, in submit Sps.sub that does the job. BUT this will not be safety rated. If you have to switch safety relevant outputs you must do it in hardware just like your laser. F. e. by a relay switching off the power supply of your output module.
