  4. ABB Robot Forum
Rapd
  • Enio
  • December 20, 2024 at 4:02 PM
  • Enio
    195
    Hello guys, we have a problem on an S4C M97 Welder.We have a routine that have a tool defined not ok. Usually this type of problem on IRC5 we solve in Robostudio with the Adjust Robotarget option,Old tooldata - New tooldata. Unfortunately we can not create a station for S4C on robotstudio version we have .Does anyone have any idea how to solve this problem without Robotstudio?. We need to have the same routine but change to a new tool we have already define with setup Bullseye
  • Lemster68
    301
    2,493
    Blog Articles
    7
    • December 20, 2024 at 4:21 PM
    Use the new tool in the move instructions.
  • Enio
    195
    • December 20, 2024 at 4:37 PM
    lemster, when I change the tool in the move instruction the tcp goes out of range,I use to go to a robot target than change the tool activate the tool and than modpos, but i have 700 line procedure ,it will take forever this way
  • Enio
    195
    • December 20, 2024 at 4:39 PM
    i need a way to convert from robot target to robot joint position and than change to robotarget with the new tool again
  • Lemster68
    301
    2,493
    Blog Articles
    7
    • December 20, 2024 at 5:12 PM
    Then you should use the function CalcJointT with the old tool and then CalcRobT on the result using the new tool.
  • Enio
    195
    • December 21, 2024 at 8:20 AM
    hello Lemster , can you show me the operation in this pice of code please , i am not sure how it is done.
    MoveJ p530, v1000, z50, tRobactaDriveCMT\WObj:=WobjSTN1;
    MoveJ p520, v1000, z50, tRobactaDriveCMT\WObj:=WobjSTN1;
    MoveJ p510, v1000, z50, tRobactaDriveCMT\WObj:=WobjSTN1;
    ArcLStart p500, v1000, seam5, weld5\Weave:=weave5, fine, tRobactaDriveCMT\WObj:=WobjSTN1;
  • DS186
    201
    1,078
    • December 23, 2024 at 11:42 PM
    Here is an example for one of your robtargets. Check the RAPID manual for detailed information.
    VAR jointtarget jtJointPos;
    jtJointPos:=CalcJointT(p530,tRobactaDriveCMT\WObj:=WobjSTN1);
    p530:=CalcRobT(jtJointPos,New_Tooldata\Wobj:=WobjSTN1);
  • Enio
    195
    • December 24, 2024 at 9:04 AM
    hello DS 186, my robotarget are not defined, is there any way to use this method anyway?
  • DS186
    201
    1,078
    • December 24, 2024 at 9:28 AM
    What do you mean with not defined? Where is the data for your targets (p500, p510, p520, etc.) coming from?
  • Enio
    195
    • December 24, 2024 at 10:17 AM
    i have the robotarget target with * so not define
  • DS186
    201
    1,078
    • December 24, 2024 at 11:00 AM
    • #11
    Okay, understand. The points are directly stored in the instructions. I'm not aware of an (easy) method to modify "*-positions".
  • Skooter
    173
    2,077
    • December 24, 2024 at 8:42 PM
    • #12
    I've had a few situations where I had to change a lot of * to robtargets/jointtargets on old systems. Took hours of cut, paste, edit with text editor, not forever. Trick was to do about 50 and then verify in the controller. Once that worked, saved the program (or routine) and moved on to the next 50. Using text editor in RS should catch common problems like missing or double commas.
    You'll appreciate the effort spent now on projects going forward.
  • hermann
    412
    2,629
    • December 25, 2024 at 10:22 AM
    • #13
    Quote from Enio
    .. Unfortunately we can not create a station for S4C on robotstudio version we have..
    Shouldn't be necessary to create a station for S4C. If the robot type is available for your robot studio just create a new station for IRC5 and load the programs into robot studio. You will have to configure i/o signals to get rid of error messages, but this normally is easy to do with search/replace in an editor after exporting eio.cfg and comparing old and new format of the projects.
Similar Threads
  • 2002 IRB2400 M2000 Model S4C+ Rebuild Help
    • Mertkan Koca
    • July 6, 2023 at 2:46 PM
    • ABB Robot Forum
  • Calculation of cubic root
    • DS186
    • June 16, 2023 at 3:43 PM
    • ABB Robot Forum
