Hello team,
I recently stumbled upon a difficulty of mine regarding the Password configuration for the Users. I created the .xml file with the help of the forum here and all the manuals i had access to, from Fanuc. It works, or it almost works. First of, I think (correct me if i'm wrong) but i need to assign every single button as <LLABEL/> from every menu, I need some clarification from you team. Also, I got the other problem, i wan to use LEVEL = 0, so everything i don't want can't be seen but if i do that and at the same time give access to "Select" the Operator, can't see it or have access to it, which is odd. On the other hand, if i upscale the Level, let's say Level=2 or 3, as i did, he end's up having access in every menu and disregards the rw_access. So, anyone willing to help guys?
