When I use KRterm connecting E-series Controller by user as , the console output is Connection Closed by AS System. May I ask what the reason is? And how should I solve it? thank you.
I also received the same return value when using telnet connection on PC. Most robots have this situation about 20,Normal login only 3.
Restarting the controller is necessary to solve this problem.
KRTerm version is 1.2.8
Connection method is Ethernet
port is 23.
